Power Steering Pump Brackets, Please help!!
Old May 25, 2025 | 08:15 AM
gibbo69olds's Avatar
Let me start by saying I know I am an idiot. I took the pump apart a while ago and now I forgot how it goes back together. I thought I took pictures because I knew this was going to happen, but I can't find them. Man it sucks getting old and forgetting stuff. I am trying to figure out how all these brackets assemble and then mount back on the engine. Can someone please take a couple pictures of the setup on their engine to help me. I would greatly appreciate it. It's a 68 Olds 455 with only the alternator and power steering pump. The pump mounts on the drivers side with the alternator on the pass side. My pics are below of the brackets and new pump. I think I have the first bracket on the pump correctly. The rest are throwing me for a loop. Thanks in advance for the help.
Old May 25, 2025 | 09:05 AM
Hopefully you didn't forget the spacers...
Old May 25, 2025 | 09:08 AM
By the way, what's going on with the cutout under the top inboard fastener location?
Old May 25, 2025 | 10:33 AM
Not really sure, never noticed the cuts before. I believe I have other brackets from the 350 I pulled out. I pulled this engine out of a delmont 88 about 20 yrs agao.
Old May 25, 2025 | 10:34 AM
Thank you for all the information, super helpful.
Old Jan 5, 2026 | 09:40 AM
70_442's Avatar
Joe_padavano
I have an assembly manual that does not have the detail that you posted. Can you point me to the supplier of the documentation you referenced?
Old Jan 5, 2026 | 09:50 AM
Originally Posted by 70_442
Joe_padavano
That page is in all the ones I've seen, but in any case, by far the best quality and most complete PIMs are from Paul Sigmund (Hairy442 on this site).
Old Jan 6, 2026 | 03:51 PM
HighwayStar 442's Avatar
I believe someone cut to fit around electric mounted water pump. Added spacers and aftermarket crank pulley would also be needed. And custom size belts of course.
WalkTall
May 26, 2023 05:26 PM
BSiegPaint
Feb 21, 2023 10:16 AM
yalikeme
Aug 16, 2015 08:59 AM
oddball
Jul 9, 2015 09:17 AM
Nov 28, 2013 12:01 PM
