Front crank seal on '72 455
Hard to say. Looks like a lot of it might be leaking from above. Clean it up with a couple of cans of brake clean and then put some uv die in the oil and see what happens. The fan can blow oil all over the place and fool you as to the source.
Looks like the rubber half moon seal between the front of the oil pan and the bottom of the timing chain cover is leaking. The good news is that there isn't any pressure there, it is just an annoyance.
The textbook fix would be to drop the oil pan and replace the gasket and seal but if you go that far might as well do a timing chain set replacement. You could just do a timing chain set replacement instead but the oil pan off is a cleaner, neater more thorough job on an older car.
External RTV usually fails as a repair for these leaks
Thanks all.
Thank you, Sugar AND Joe. Sugar, I don't disagree on doing timing chain set replacement - but on a car with 60k miles... I wonder how much it really needs it. Joe, I can certainly check the oil pan bolts but doesn't it look like the leak is starting from higher up on the front of the engine than the pan area? Rather not have to unbolt the engine and lift (however much) to get pan off/out. But, if I gots to then I gots to. It's making a real mess as the oil slide to the back of the engine/oil pan. This ain't no show car but I also don't want to be "that guy" dripping oil around town.
Thanks all.
Thanks all.
The engine may only have 60k on it, but it’s still 50 years old. It might not be flaking off now, but give it time.
60K miles is very favorable; but,...the nylon is 50 years old. Pulling either the oil pan or the front cover aren't fun/trivial and your 80% of the way there so if you pull the pan or the front cover I'd suggest considering doing the chain. As the nylon shreds or breaks off in chunks it clogs the oil pickup tube on the oil pump and starves the entire engine for oil. IMHO, neither the oil leak or the chain are issues that need urgent attention, but if you decide to do one do both.
