Heater control Valve
Old Dec 17, 2023 | 12:42 PM
Chuxter's Avatar
1970 Cutlass Supreme
So last question today. Again I have a 1974 455 that I am putting in a 1970 Cutlass Supreme and they are calling for 2 different heater control valves. Which one do I use?
Old Dec 17, 2023 | 01:05 PM
OLDSter Ralph's Avatar
I would suggest the heater control valve for the car its going into. Shouldn't it work with heater controls in the car to work properly ?
Old Dec 17, 2023 | 01:53 PM
Correct, you need the valve that works with the vehicle’s system. Note the thread diameter is different between the 1970 and 1974 heater valves and intake manifold ports.
Old Dec 17, 2023 | 01:59 PM
Chuxter's Avatar
So i would need a pipe thread reducer to make that work Correct?
Old Dec 17, 2023 | 02:06 PM
I used one of these.
Old Dec 17, 2023 | 02:17 PM
Chuxter's Avatar
Thank you for the info I apreciate it very much.
Old Dec 17, 2023 | 06:31 PM
Your 70 requires a heater control valve that is normally closed and opens when vacuum is applied. The 1974 heater control valve is normally open and closes when vacuum is applied, so exactly opposite of what the car needs. And be careful if buying a new one. Like most Oldsmobile parts, nearly all of the vendor catalogs have these valves listed incorrectly.
Old Dec 17, 2023 | 06:50 PM
Chuxter's Avatar
Thanks Joe, you've been busy answering a lot of my questions today.
Old Dec 19, 2023 | 04:37 PM
Chuxter's Avatar
does any one know the size of reducer i need to put the 1970 valve in the 1974 intake?
Old Dec 20, 2023 | 11:28 AM
3/4” outside diameter
1/2” inside diameter
Old Dec 20, 2023 | 11:48 AM
edzolz's Avatar
Remember these are pipe thread sizes. Probably would be 1/2 inch pipe and 3/8 pipe thread, or 3/8 and 1/4 pipe.
Kapos79kutlass
Nov 9, 2023 12:07 PM
Kapos79kutlass
Nov 5, 2023 12:36 PM
ajr2820
Nov 2, 2023 02:00 PM
doc93
Jan 26, 2011 08:10 PM
toms66rgtop
Aug 31, 2008 09:58 AM
