Has anybody used this engine bolt kit ?
Old Dec 9, 2021 | 07:28 AM
BillK's Avatar
One of my customers asked me about this bolt kit for a 455 he is doing. Just a nice street engine. I had never heard of them and to me the price is too low to be worth a darn ? But they do have very good feedback. Has anybody bought them ?
https://www.ebay.com/itm/13269845086....c101113.m2108
Old Dec 9, 2021 | 08:24 AM
OLDSter Ralph's Avatar
No mention of the Grade equivalent (Grade 5, Grade 8) the bolts are.
I think lube on the threads to keep from galling and torque specs would be needed.
The ad mentions ARP bolts are available. Hmmmmm why ?
304 SS is mentioned, but not the country of origin. I am not impressed with metalurgical consistency from certain foreign countries.
What is the advantage by using SS hardware ? Rod bearing caps, and main bearing caps are not subject to corrosion.
......Just my two cents worth.
Old Dec 9, 2021 | 08:55 AM
BillK's Avatar
304 SS is mentioned, but not the country of origin. I am not impressed with metallurgical consistency from certain foreign countries.
I sort of agree with you Ralph. All of the hardware in the kit is external and the stainless does look nice. If you go to the web site they are an ARP distributor and just offer that as an upgrade. Also ARP does not list a bolt kit for Oldsmobile. Almost all stock external hardware that I see on a daily basis is only Grade 5 or less so that might not be an issue.
These types of bolt kits are great if you are starting out with a 50 year old engine with a bunch of rusted junk to begin with. Trying to source everything separately can be a pain. Thats why I am asking if anyone has seen this particular vendors parts and can offer some feedback.
Old Dec 9, 2021 | 09:10 AM
The bolt positions advertised do not require high clamping pressure, stainless will work fine. Price is not bad, plus free shipping.
Old Dec 9, 2021 | 10:33 AM
4speed455's Avatar
I used a kit from this vendor for my motor. I went with the socket head stainless Allen bolts. No complaints from me. The kit had everything I needed and still looks great 10+ years later.
Old Dec 9, 2021 | 01:55 PM
Did this kit contain rod bolts, main bearing cap bolts and head bolts ?
Old Dec 9, 2021 | 02:33 PM
4speed455's Avatar
The kit I used only had external fasteners. Valve covers, intake manifold, thermostat housing, water pump, timing cover, fuel pump, oil filter adapter, oil pan, pulleys and a few other things. I remember I had to specify which intake I was using and I think also if I was using exhaust manifolds or headers.
Old Dec 9, 2021 | 06:37 PM
BillK's Avatar
No, it is strictly external hardware like valve cover bolts, intake bolts etc. More than likely a step up from the stock stuff no matter where it comes from.
Old Dec 9, 2021 | 08:37 PM
Ok, then it should be fine.
Old Dec 10, 2021 | 05:38 AM
chopolds's Avatar
I use stainless whenever I do a more detailed engine build. I get the bolts locally, from a steel supplier, who sells them by the pound. I even grind off the markings and polish the heads. Never had any problems, and you DO have to use anti-seize on them. On my 'new' 455, I did this and used ARP for rod and head bolts.
Old Dec 19, 2021 | 07:39 PM
oletrux's Avatar
I use stainless on my builds too......not for high-strength or high-stress situations tho.......normally buy from Totally Stainless or my local Ace Hardware in a pinch. I always, always use anti-sieze with stainless hardware.
Old Dec 21, 2021 | 06:13 AM
oddball's Avatar
FWIW, I use Allens Fastenders for my misc fastener needs. He has an excellent selection of hard to find stuff, and sells ARP by the piece, at decent prices.
Kyron219
Feb 21, 2016 02:57 PM
dancutlass
Dec 4, 2011 03:46 AM
442GirlInOkla
Mar 4, 2009 07:13 PM
1g1yy
Feb 6, 2009 08:36 AM
68Tom
Dec 4, 2008 10:20 AM
