455 Connecting rod to cam lobe clearance.
Installed my Eglin cam today .496" Intake .520" exhaust ..... 224 Intake 234 Exhaust @ .050 ...... My build includes Con. Rod H-beam connecting rods ....turning the engine over with 1/2" rachet at crankbolt found #4 connecting rod at the top portion ( shoulder ) of the rod where the rod bolt screws in hitting the the very top of the camshaft lobe , removed #4 piston & rod and am going to bring it to the machine shop to grind down a small portion for clearance & rebal.
With #4 rod and piston removed I was able to turn the crankshaft freely also checked all other cam lobe to rod clearance and they seemed fine except #8 cylinder seemed a little close , I happened to have very long feeler gauges
and measured .008 clearance ..... any thoughts ? does this seem too close ?
Engine is on an engine stand timing chain not installed .... Or will having the timing chain installed keep cam/crank timed thus keeping the lobe of the cam in proper distance from the crank ....was turning the camshaft by hand to various positions when I came across this...
Thanks in advance
Thanks in advance
Put the timing chain on , engine spins over no problem . I have never experienced this issue before . Kinda strange I have never experienced this before or heard of anyone running into this . Like I mentioned it was only when the crank was in a certain position .
THX for the input .
THX for the input .
