455 Connecting rod to cam lobe clearance.
Old Oct 23, 2021 | 02:49 PM
jskorz's Avatar
Installed my Eglin cam today .496" Intake .520" exhaust ..... 224 Intake 234 Exhaust @ .050 ...... My build includes Con. Rod H-beam connecting rods ....turning the engine over with 1/2" rachet at crankbolt found #4 connecting rod at the top portion ( shoulder ) of the rod where the rod bolt screws in hitting the the very top of the camshaft lobe , removed #4 piston & rod and am going to bring it to the machine shop to grind down a small portion for clearance & rebal.
With #4 rod and piston removed I was able to turn the crankshaft freely also checked all other cam lobe to rod clearance and they seemed fine except #8 cylinder seemed a little close , I happened to have very long feeler gauges
and measured .008 clearance ..... any thoughts ? does this seem too close ?
Engine is on an engine stand timing chain not installed .... Or will having the timing chain installed keep cam/crank timed thus keeping the lobe of the cam in proper distance from the crank ....was turning the camshaft by hand to various positions when I came across this...
Thanks in advance
Old Oct 23, 2021 | 04:16 PM
edzolz's Avatar
Dayum!! I never thought there was that little clearance between the cam and rod bolts. Maybe it is the type of rod you are using.
Old Oct 23, 2021 | 05:17 PM
442Harv's Avatar
You said the timing chain is not installed? If so, I would install and check, maybe you have the lobes out of sinc,I never heard of the clearance problem you stated, on a Olds before.
Old Oct 23, 2021 | 05:20 PM
BillK's Avatar
If you dont have the timing chain installed that is probably your problem. Put the chain on and try again. I bet you have plenty of clearance then.
Old Oct 23, 2021 | 06:40 PM
cutlassefi's Avatar
^^^^^^^. Put the chain on it, you’ll have a mile and a half clearance.
Old Oct 27, 2021 | 11:35 AM
jskorz's Avatar
Put the timing chain on , engine spins over no problem . I have never experienced this issue before . Kinda strange I have never experienced this before or heard of anyone running into this . Like I mentioned it was only when the crank was in a certain position .
THX for the input .
Old Oct 27, 2021 | 01:55 PM
bccan's Avatar
Pheeew!
Alaska442
Mar 14, 2021 06:18 AM
delta881972
May 14, 2020 12:41 PM
Texas69
Apr 7, 2015 09:54 AM
805cut
Jun 11, 2012 05:06 AM
MY71CUTLASS
Oct 4, 2007 12:21 PM
