Spark Plug recommendation - 455 W/Speedmaster Heads
Old Oct 20, 2021 | 11:25 AM
jskorz's Avatar
Looking for spark plug recommendation for street driven 455 , 10.0 to 1 compression , Keith Black hyper. pistons , rebuilt quadrajet , cam. - 496" int. , 520" exh. , 224 int. 234 exh. @ .050 duration , factory 1978 40k volt High Energy Ignition for now ( stock ignition curve ) , 3.08 rear , Speedmaster Heads .
Looking for spark plug manufacturer and part # ( will not use champion plugs )
Thanks in advance
Old Oct 20, 2021 | 02:59 PM
bccan's Avatar
ASSuming they’re the same as Edelbrock Gen 1 heads, mine are NGK BKR 7E. I don’t know if they’re ideal as I haven’t removed one in 10 years despite a new set sitting on the shelf.
Old Oct 20, 2021 | 08:33 PM
edzolz's Avatar
There is a spark plug cross reference in the Tech Editor's Desk section.
Old Oct 21, 2021 | 04:25 AM
BillK's Avatar
What do the Speedmaster heads recommend ? That would be the first choice.
Most aluminum heads use a 3/4" reach gasketed plug. Champion RC12YC would be my starting point. Not sure why you dont like Champion but you should be able to cross reference that number.
Old Oct 21, 2021 | 05:59 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
A lot of people had issues with Champion plugs. My Uncle would not run them in anything, except small engines, which seemed Ok. My Boss who was a licensed mechanic would not stock them till Champion came out with the truck plug, it took a money back guarantee, I believe, a really nice plug, nothing but issues with the regular plugs, this was 20 years ago. The rumour was once lead was removed from fuel, Champion plugs ran terribly but who knows. Obviously, all the plugs, except maybe NGK, have changed their design and place of manufacturing over the years.
Old Oct 21, 2021 | 07:06 AM
Duh's Avatar
Duh
NGK BKR7E is a good start from the info you gave.
Champion made excellent race plugs up to a few years ago. Recently quality is not there and they discontinued alot of part numbers. I used to run C61YC's in my old motor 11:1. I had one NOS set of C63YC that I ran in my current motor, ran good but could not get a new set, discontinued.
Old Oct 22, 2021 | 02:03 PM
cutlassefi's Avatar
Also known as a 4644. BKR6E would be a 6962.
Hope this helps.
oldman8187
Oct 24, 2021 06:08 AM
70442rag
Jan 7, 2017 05:51 PM
HWYSTR455
Jul 13, 2014 09:46 AM
72442clone
Jul 15, 2011 11:53 AM
