Brackets
Old Aug 16, 2009 | 09:28 AM
suppressivefire's Avatar
Brackets
sorry to hijack but i have a 455 that had ac which im not using, that means i can use all my 350 brackets pulleys etc on the 455?
Old Aug 17, 2009 | 08:43 AM
I moved your post because the old one was six months old. Yes, if the 350 is 1977 or older the brackets will work on the 455.
Old Aug 23, 2009 | 01:29 AM
ok how about the pulleys it seems you need to also swap waterpumps?
side question will a 69 442 cam go into a 72 for a performance boost?
Old Aug 23, 2009 | 07:49 AM
Pulleys, pump, and brackets must be used as a matched set for proper alignment since there are three different water pump lengths.
All 64-90 Olds V8 cams interchange, but cam profiles have come a long way since 1969.
Old Aug 24, 2009 | 08:41 AM
marzgtp1's Avatar
Olds-Can
Joe what is the differace in a hd water pump compared to a non a/c water pump? is it just a better pump? I just bought one at the parts store and they said it was just made better?
Old Sep 3, 2009 | 09:17 PM
Thanks I was just wondering about the cam because the engine i just picked up was a 72 and the guy gave me a 68 or 69 cam i was just wondering if it would boost hp at all.
olddaz
Aug 27, 2014 06:39 PM
ERIC27
Mar 3, 2013 11:14 AM
HWYSTR455
Aug 30, 2006 04:40 AM
TOONLOVESCHERYL
Jul 4, 2006 08:07 AM
