I had the rear main seal on my 455 replaced this summer. That addressed a slow leak that I had been having. But now the leak is back...though I'm not sure it's from the same place. I have a suspicion oil might be leaking down from somewhere else.
When doing a quick visual of the motor I noticed this little bit of oil.
When I ran cast iron heads I remember having the same issue. My guess is oil seeping around the bolts (as someone previously mentioned). Retorque the bolts, put some Teflon paste on the bolts threads in the center of the manifold.
