Height of 455
Old Nov 15, 2020 | 11:56 AM
Minnesotajeff's Avatar
Height of 455
Getting ready to pull the 455 out of my cutlass and wondering if anyone knows the height of the motor from the intake manifold pad to the bottom of the oil pan. I have a 4 post lift that I’d like to have the car on when I pull the motor, but I will have to have the car raised about 8 inches so my engine hoist legs can roll under the lift cross bar to get in picking position. Trying to figure out if I’ll be able to lift the motor high enough to clear the front of the car.
Old Nov 15, 2020 | 02:34 PM
RetroRanger's Avatar
72 Olds CS
I just measured my 350 from the lowest point on the oil pan to the highest edge ofthe valve cover ( no in take on it) its about 22” bbo is at least 1” taller.
when i removed the sbo it was tight to get over the rad n coresupport because you need to extend the boom out pretty far to reach over the core support, my garage has 10’ ceiling. When i put the bbo in i took off the hood and used a chain fall an over head beam, it was easier than the engine hoist.
Old Nov 15, 2020 | 03:07 PM
Old Nov 15, 2020 | 07:20 PM
Thanks Joe, that’s awesome
JPinAZ
Sep 15, 2020 03:26 PM
leadfoot067
Dec 3, 2010 06:11 PM
captn442
Sep 18, 2010 11:33 AM
1973olds98
Sep 26, 2009 01:59 PM
455john
Jan 14, 2007 08:10 PM
