Engine not fired in 10 years
Old Aug 9, 2020 | 04:21 PM
Bassemaa93's Avatar
Hello, I am about to buy a 1974 442 that has been parked for almost 10 years. What should I do first before trying to fire the engine? I don't want to hurt it. Thanks.
Old Aug 9, 2020 | 05:01 PM
Sugar Bear's Avatar
See if the engine turns by hand first before using the starter. If you really want to do it right remove the spark plugs and put approx a teaspoon of thin oil in each cylinder and rotate the engine by hand a few times with the plugs out.
Check the oil level and if it looks really bad drain and refill the pan.
Good luck!!!
Old Aug 9, 2020 | 06:24 PM
Ideally, remove the distributor and prime the oiling system. If that’s not feasible, disable the ignition, and crank the engine with the spark plugs removed. Crank it until the gauge (if equipped) shows oil pressure, or the light goes out.
Old Aug 9, 2020 | 07:16 PM
If the fuel smells like varnish, drain and clean the tank first or use a remote gas can.
Old Aug 9, 2020 | 07:18 PM
Kennybill's Avatar
Here's a thread with some good tips, jmo.
http://www.v8buick.com/index.php?thr...ng-car.359259/
Dweems
Jul 28, 2020 11:57 AM
72cutlass408
Feb 25, 2020 07:02 PM
tailfins
Jan 16, 2019 06:00 PM
317rcampbell
Paint
17
Nov 25, 2009 04:28 AM
captjim
Jul 15, 2009 08:53 AM
