Removing/installing exhaust manifold on a 425
Old Jul 15, 2009 | 11:23 PM
rustyold66's Avatar
I want to replace my driver's side manifold on my 66 Delta 88 with a Thornto dual repro I have. Should I lift the motor or can I do it with the engine still in the bay?
Thanks!
Old Jul 16, 2009 | 04:30 AM
442scotty's Avatar
Might have to pull the starter...that should do it
Old Jul 16, 2009 | 09:21 AM
It might be easier to just pull the steering shaft.
Old Jul 18, 2009 | 12:40 AM
rustyold66's Avatar
Thanks for the suggestions. I'll give 'er a better look-see tomorrow.
Old Jul 18, 2009 | 05:56 AM
Oldsmaniac's Avatar
You should not have to lift engine. If engine mounts are compressed it makes it tougher. Yes remove starter. Hardest part will be removing bolts as over time the heads have become slightly smaller due to rust. Make sure you use a 6 point socket and you may have to go from a 9/16 to a 14MM for a better fit. The factory tin keepers if still there on the bolt heads are fun too. You can unbend the tabs from below with a long screwdriver and hammer. Hopefully you wont run inta a problem that happened to me once. The center bolt was crossthreaded. I tried everything I could and ended up twisting the head off of the bolt. I then tried getting the broken piece out of the head and that broke too. Had to pull the head and retap threads.
smcurro
Mar 16, 2018 08:37 PM
65Delta
Dec 1, 2016 06:35 PM
Mak
May 1, 2015 07:07 PM
fv64olds98
Body work
Mar 12, 2013 04:50 PM
53sled
Dec 21, 2009 08:47 PM
