Correct clamps for bypass hose?
Old Jun 13, 2019 | 11:09 AM
72455's Avatar
1972 U code Supreme
Hey all...
I'm looking for the correct style hose clamps for the bypass hose on my '72 U code Supreme. I see two different ones on the interweb, so not sure if it's the wire style or the band style...can those that know clarify pls?
Thx,
Dave
Old Jun 13, 2019 | 11:37 AM
green1972's Avatar
Hi Dave,
https://www.yearone.com/Product/1964-72-cutlass-442/w40 the last i saw these were old stock , Tim
Old Jun 13, 2019 | 12:52 PM
72455's Avatar
1972 U code Supreme
Thanks...got em ordered along with a GM stamped bypass hose.
Old Jun 13, 2019 | 08:42 PM
costpenn's Avatar
The Wittek style clamp is correct for 71-72, the double wire style are for earlier models. Be careful with that bypass hose. The resto houses version with the big ink stamped numbers is made out of incredibly flimsy and thin rubber. These can fail and spray you engine compartment with a sticky coolant bath. Use a Gates or Goodyear bypass hose. It is worth it!!
Old Jun 14, 2019 | 01:39 AM
72455's Avatar
1972 U code Supreme
Uh oh...does the same hold true for the upper and lower rad hoses as well? I ordered those too...and what about the GM stamped belts?🤔... need to ASAP know so I can cancel my order on the hoses if need be.
Old Jun 14, 2019 | 11:18 AM
rocketraider's Avatar
Oldsdruid
This actually applies to 74, but the 74 Cutlass Assembly Manual shows double-wire clamps used on Lansing cars and the Wittek towers for all other assembly plants. May be the same other years. More Olds weirdness...
Old Jun 14, 2019 | 11:42 AM
72455's Avatar
1972 U code Supreme
Thanks but I'm trying to find out if the repop upper and lower hoses are durable? I ordered those from The Parts Place and my bypass hose from Year One...
Old Jun 14, 2019 | 03:49 PM
Aren't those show car restoration hoses and you're not expected to actually drive your car with them?
Old Jun 14, 2019 | 04:10 PM
72455's Avatar
1972 U code Supreme
I dunno that's what I'm trying to find out...
Old Jun 18, 2019 | 04:59 PM
costpenn's Avatar
The repo rad. hoses themselves are OK for normal usage. The bypass hose on the bend is where you very well might have a failure. Even the original ones were prone to fail - that is why Olds changed the design in '71 to the metal tube with short connecting hose type.
Old Jun 18, 2019 | 05:00 PM
72455's Avatar
1972 U code Supreme
Ahhh...so that 'splains the difference...I was wondering why the two different designs.🤔
sevntyW30auto
Feb 4, 2019 05:18 PM
droldsmorland
Jan 17, 2018 05:09 PM
Bfg
Jul 21, 2017 08:50 AM
377rick
Mar 23, 2014 05:04 PM
at3reg98
May 4, 2012 08:22 PM
