Seeking Carburetor selection advice
#81
We're hanging in up here in the mitten, warmed up today and supposed to be even warmer tomorrow....go figure. The last 3 days were brutal, coldest on record I believe. Definitely wernt spraying any weedz.....lol
#82
Better today though and 40s with rain tomorrow. That should make the 12 or so inches of snow we've had nice and sloppy, lol.
Carburetor came today. Man I love ordering from Summit. Two days to my door with the free shipping. Everything looks good.....in the box. Lol.
#83
I have a 625 cfm version coming my way, too cheap to pass up. I plan on tuning it and see how it does for performance and mileage compared to my custom tuned 800 cfm Everyday Performance Qjet on my Olds 350.
#84
mac had the same thing here at 10 below zero my garage heater wouldn't run with about a quarter tank in my 100 pounder.switched to a 20 pounder and it didnt make it through the night .much warmer here today .good luck with your carb
#85
I have 3 electric heaters, 2 radiant heat and one with a fan, it just makes it acceptable in -40. I will be insulating the walls and installing the new opener on the new R value 26.8 door before next winter.
#86
https://sprayfoams.info/the-r-value-myth/
Then there is this
https://www.youtube.com/user/MyanmarLiving/videos
#87
I did a little research and it sounds like the bioling point for LP gas is -44*. At -22* we were mighty close to just having the L of LP gas. It makes sense that I lost pressure. Nit sure what to do about it if it happens again. I've read an electric blanket can help but that would make me a little nervous, obviously.
I'm done heating my shop in the winter. It just costs too much for what little time I get out there in the winter. I covered the wallls in 2" styrofoam before drywalling, 1" foil-backed on the ceiling, and an insulated door that I screw shut and tuck memory foam along the top. It's pretty air-tight but that darn concrete floor stays ice cold.
50 degrees out there today! Lol.
#88
Kerosene heaters without fans, and larger forced air radiant heaters might come in handy along with a barrel of Kerosene.
#89
A few things to consider
Then there is this
Then there is this
#90
I see where they come from. Either way the door is insulated and the edges are well sealed. The 3 windows help light a lot. I plan on bat insulation then vapor barrier on the walls. I will do either fiberglass sheets or reflective foil and insulation rolls just above the lower rafter supports. I plan on parking my 2017 Challenger GT in there next year. I also added a second power bar and 4 ft 40W LED shop light, puts out a lot of light. I only can run 30 amps out there so I need as many high efficiency lights, also have another 4 ft fluorescent and a 100 watt equivalent LED bulb in the light socket.
#92
I know one racer, in a magazine article said the 625 dynoed at 500, or a little more on an LS engine.
On the secondaries the flapper valve on the Thermoquad had a dampening pot. It prevented them opening until the choke came off, and slowed the rate of opening down some. I think if there is a problem for some on the secondary its the fuel not starting fast enough, but there is a simple fix for that, if true.
https://mooregoodink.com/evil-twins-...hotrod-engine/
69ishHoliday
August 18th, 2013 06:31 PM
