water in cylinder
Old December 7th, 2018, 10:57 AM
jerryl's Avatar
water in cylinder
I hav e a 69 442, I left my car at a shop to be painted,i told the owner to keep car inside as it was apart. I wrapped the engine to keep it safe as was just rebuilt.when I went to check on car found it outside,raised hell.they put it back inside.eventually took car out of shop because not happy,when I got car home tried to turn engine by hand to keep free, water came out of spark plug holes on two cylinders,motor did turn over a little.pulled off heads found corrosion inside got most cleaned up,but one cylinder concerns me,don't want to tear completely down,or replace engine .car is original numbers matching,any suggestions?
jerryl is offline
Old December 7th, 2018, 11:42 AM
How did water get in? Were the spark plugs out, carb off, intake off, or???
Fun71 is offline
Old December 7th, 2018, 12:38 PM
jerryl's Avatar
water came in through carb air cleaner when guy left outside and covering came off,don't know how long it was like that before I checked on car and screamed about it !! was supposed to be kept inside with engine covered with plastic over engine and tarp over entire car.
jerryl is offline
Old December 7th, 2018, 03:54 PM
RandyS's Avatar
I think I would have done a bit more than scream at the dude. He would be getting out of the ER about now.........
RandyS is offline
Old December 7th, 2018, 04:22 PM
Sugar Bear's Avatar
It depends on how severe the corrosion is. Post a picture if you can. Best case scenario may be remove the piston in the cylinder in question, hone that cylinder and check the result.
Sorry to hear and good luck!!!
Sugar Bear is offline
Old December 7th, 2018, 06:49 PM
snd send the bill bill to the body shop that caused the damage!!!
matt69olds is offline
Bassemaa93
August 19th, 2019 06:57 AM
rustyroger
Tech Editor's Desk
October 10th, 2013 06:49 PM
TenMidgets
June 20th, 2013 07:10 AM
The Stickman
September 9th, 2009 06:16 AM
J-(Chicago)
October 25th, 2008 11:10 AM
Quick Reply: water in cylinder
