question 350/455 motor mounts
Old Jun 12, 2018 | 06:25 PM
matviar's Avatar
Red face question 350/455 motor mounts
On my 1970 Cutlass convertible, I am replacing a 350 rocket with a 455. Do I need to replace the engine mounting pads that are bolted to the frame ? I've seen suppliers that sell 455 pads. Can I re-use my 350 pads?
Old Jun 12, 2018 | 06:29 PM
Cincinnati Rick's Avatar
Take a look at this thread.
https://classicoldsmobile.com/forums...tion-list.html
Old Jun 12, 2018 | 06:41 PM
matviar's Avatar
Angry
Let me put this another way. Is there a physical difference between the 1970 Cutlass 350 frame pad and the 455 frame pad?
Old Jun 12, 2018 | 07:03 PM
svnt442's Avatar
Yes, but there is no reason to swap them. Just use 350 mounts and be on your way.
Old Jun 12, 2018 | 07:36 PM
tru-blue 442's Avatar
Old School Olds
What Randy said.
Old Jun 13, 2018 | 12:16 AM
matviar's Avatar
So since I am using the original 350 frame mounts, I should use the 350 motor mounts on my 455?
Old Jun 13, 2018 | 04:12 AM
Old School Olds
Yes.
Old Jun 13, 2018 | 05:34 AM
matviar's Avatar
Red face
Thanks for Your input. Those 455 frame mounts are pricey !
Old Jun 13, 2018 | 06:31 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Search function is your friend. Joe P. has addressed this question probably at least a dozen times or more. Now you are going to save some money.
Old Jun 13, 2018 | 10:56 AM
Probably more like a dozen times THIS YEAR...
I'll also take this opportunity to again suggest that we stop calling them "350" and "455" mounts. Through the 1968 model year, the first design mounts (with the 2261 rubber mounts) were used with EVERY Olds block in an A-body, from 330s through the 455 in the 1968 H/O. The second design mounts (the stronger ones with the 2328 rubber mounts) were similarly used with EVERY Olds block from 1973-up, including the 260 and 455. It was only model years 1969-1972 where the two designs were used in the same year, and this has led to an infinite number of posts.
Bozang1
May 1, 2015 12:56 PM
matviar
Jan 25, 2012 05:07 PM
JUMBOJIMBO
May 15, 2011 11:24 AM
442scotty
Sep 16, 2008 04:54 PM
shaks 442 clone
Jul 29, 2007 09:27 PM
