350 to 455 swap
Old Jan 24, 2012 | 05:10 PM
matviar's Avatar
Question 350 to 455 swap
This has probably been asked 1000 times. I am putting a 1970 455 in my 1970 cutlass cv. It was factory 350. My question is, can I use my existing frame pads and motor mounts from the 350 engine.
Old Jan 24, 2012 | 07:03 PM
cutlassefi's Avatar
You're right, do a search.
Old Jan 24, 2012 | 07:33 PM
sklbndt's Avatar
Yes. Not only "can" you, you "need" to. Otherwise you would have to swap out both the frame and engine mounts.
x2 on what cutlassefi said. Just search 350 455 swap and you'll find a ton of information.
Good Luck!!
Old Jan 25, 2012 | 04:35 AM
507OLDS's Avatar
Use the 350 motor mounts,with the 350 frame pads,and everything will line up.
Old Jan 25, 2012 | 08:43 AM
Which would turn up this thread:
https://classicoldsmobile.com/forums...tion-list.html
Old Jan 25, 2012 | 01:37 PM
matviar's Avatar
Thanks!
Nice to know I dont have to shell out more cash on motor mounts. People like you make this hobby more enjoyable. Thanks
Old Jan 25, 2012 | 03:54 PM
jag1886's Avatar
For the few bucks it costs I'd replace the 41 year old motor mounts anyway, Way easier to do it now than after one pops and you have to replace it in the car.
Old Jan 25, 2012 | 05:07 PM
matviar's Avatar
They are brand new. I had to replace them. The fan was rubbing the lower part of the shroud. They must have been pretty squashed!
falconsfan
May 14, 2015 05:47 AM
oldrelics
Non-Olds Engines
Jun 12, 2014 07:09 PM
mcutlass1969
Jun 11, 2009 06:27 AM
shaks 442 clone
Jul 29, 2007 09:27 PM
Charger1973
Dec 3, 2006 08:43 PM
