double roller timing chain interference w/ fuel pump
Old May 29th, 2018, 10:58 PM
NotDads442's Avatar
My cloyes double roller timing chain will not allow my fuel pump arm to make contact with the eccentric. Do I have to use a single roller chain?
NotDads442 is offline
Old May 30th, 2018, 08:32 AM
2blu442's Avatar
I'm pretty sure it should work with the double roller timing chain. Just to be sure your putting it in the right way. Do you have the fuel lines on the top or bottom of the fuel pump when your putting it in? Olds is opposite of Chevy so this is a mistake sometimes made. John
2blu442 is offline
Old May 30th, 2018, 08:36 AM
2blu442's Avatar
Once installed it should look like this.
2blu442 is offline
Old June 2nd, 2018, 06:12 AM
71cutlassdroptop's Avatar
Any updates? I am looking at changing my timing chain and was looking at a double roller.
71cutlassdroptop is offline
Old June 2nd, 2018, 07:00 AM
RandyS's Avatar
Most every rebuilt Olds motor has a double roller chain with no interference with the fuel pump arm.
RandyS is offline
Old June 2nd, 2018, 08:07 AM
BackInTheGame's Avatar
Cloyes Double Roller
I installed a Cloyes double roller set with no issues on my '68 400CID.
I thought I had a better picture of the installation showing the whole pump and both gears, but do not. Below you can see the installed set.
BackInTheGame is offline
Old June 2nd, 2018, 06:10 PM
Old June 2nd, 2018, 07:35 PM
NotDads442's Avatar
Yes it was upside down. Looking at too many fords and chevys....
gunmetal71
May 6th, 2018 08:56 AM
atkinsom
May 14th, 2013 07:48 PM
jkoester122
September 1st, 2011 06:39 AM
eric72
March 1st, 2010 06:22 PM
1arunem
February 15th, 2009 04:48 PM
Quick Reply: double roller timing chain interference w/ fuel pump
