Help with early 425 identification
Old January 18th, 2018, 03:58 PM
67cutlassguy's Avatar
Hello again everyone! I located an early 425 4bbl for sale, and have some questions about the casting numbers. I was ideally looking for a starfire engine or a 39° Toro 425. This one's block casting is 386525A and the heads read 383821. From online info, It seems to be a 1965 with 45°cba but I can't find any info about compression, etc. The head numbers seem to say they're from a 1965 400c.i. ?? Any info from you guys would be a great help! Thanks.
67cutlassguy is offline
Old January 18th, 2018, 06:15 PM
Oldsmaniac's Avatar
That is for sure a 65 A block 425 and the heads for that engine would also be A heads. Looks right to me and that would be a 45 degree cam bank engine.
Oldsmaniac is offline
Old January 18th, 2018, 08:33 PM
thanks. Do you think the heads are off a 400? And is it a high compression engine?
Old January 18th, 2018, 08:39 PM
2blu442's Avatar
I agree with Oldsmaniac that the heads would also match what came on the 1965 425. To verify the original application remove the alternator and look for a stamp on the end of the passengerside head. That stamped code will key out what that head originally came in/on.
2blu442 is online now
Old January 18th, 2018, 08:40 PM
Also, I'm not familiar with quadrajets earlier than my 1967...is that a qjet on there? It appears different
Old January 18th, 2018, 08:42 PM
2blu442's Avatar
Its called a 4 jet and was the Rochester 4 bbl carburetor before the quadrajet was developed.
Old January 18th, 2018, 08:46 PM
great, thanks!
Old January 18th, 2018, 08:49 PM
So like my 1967 330, there's a headstamp on front passenger head. What does the 383821 designate on the head there near the spark plug?
Old January 19th, 2018, 04:48 AM
Oldsmaniac's Avatar
If the 4bbl carb and intake are original to the block its is a HC engine.
Old January 19th, 2018, 07:02 AM
That's the casting number for the 1965 "A" head. These same castings were used on all 400 and 425 motors in the 1965 model year. They have the one-year-only 3/8" rocker studs instead of the more common 5/16" bolts. The carb is a Rochester 4GC, which was the standard GM four barrel until the Qjet came out in the 1966 model year. The 4GC will say QuadJet on the air horn casting, which is why it often gets confused for a QuadRAjet carb. The engine looks to be very original.
joe_padavano is offline
jmos4
July 1st, 2016 07:42 PM
Oldzman71
June 1st, 2015 04:56 AM
therobski
August 11th, 2012 06:12 PM
DennisG.
October 29th, 2008 10:31 AM
2blu442
October 27th, 2008 10:42 PM
Quick Reply: Help with early 425 identification
