crankshaft
Not Mondello!
Check these places
Rocket Racing ( bought one from them)
Dick Miller Racing ( great source for Olds stuff)
Summit ( bought one from them but at the time they did not have any drilled for four speed)
I'm sure there's more sources. I got less than perfect from Mondello (Lynn W)with no refund policy.
I bought a billit crank from Rocket Racing. Pricey but awesome. My last cutlass had one from Summit. No problems. If you can, get one that's drilled for a four speed, just in case you decide later to convert.
Jw,
Is your crankshaft totally killed or can it be reground ? If it can be reground that is the route I would go as long as there is a decent crank grinder in your area. Stay away from crankshaft "kits" They are mostly all done by one or two big rebuilders and usually are not worth a darn.
If you want new Eagle has one, not sure about Scat.
raymondh
Aug 14, 2008 04:56 PM
