crankshaft
Old Sep 29, 2017 | 06:38 AM
jwr7042's Avatar
crankshaft
Need new crankshaft for 70 442 with 455. Where would be a good place to purchase. I see alot of places just was looking for some advice. Motor has some updates.
Old Sep 29, 2017 | 04:55 PM
Macadoo's Avatar
You might have better luck posting in the parts-wanted section. Good luck with your search.
Old Sep 30, 2017 | 07:11 AM
Gary M's Avatar
Not Mondello!
Check these places
Rocket Racing ( bought one from them)
Dick Miller Racing ( great source for Olds stuff)
Summit ( bought one from them but at the time they did not have any drilled for four speed)
I'm sure there's more sources. I got less than perfect from Mondello (Lynn W)with no refund policy.
I bought a billit crank from Rocket Racing. Pricey but awesome. My last cutlass had one from Summit. No problems. If you can, get one that's drilled for a four speed, just in case you decide later to convert.
Old Oct 2, 2017 | 03:55 AM
74sprint's Avatar
If you need extra strength Scat makes 2 billet cranks.
88-455O-4500-6800-2200 is a 4.5" stroke and 88-455O-4250-6800-220 is a 4.250" stroke.
Old Oct 2, 2017 | 05:15 AM
BillK's Avatar
Jw,
Is your crankshaft totally killed or can it be reground ? If it can be reground that is the route I would go as long as there is a decent crank grinder in your area. Stay away from crankshaft "kits" They are mostly all done by one or two big rebuilders and usually are not worth a darn.
If you want new Eagle has one, not sure about Scat.
Old Oct 2, 2017 | 09:15 PM
jwr7042's Avatar
crank has already been reduced so need new one thank you
sssingo
Nov 9, 2008 03:47 PM
raymondh
Aug 20, 2008 03:45 AM
raymondh
Aug 14, 2008 04:56 PM
poorpea
Jul 13, 2008 06:04 PM
Swed Olds
Jul 26, 2007 02:55 PM
