Water pump ID and pics
Old Feb 1, 2016 | 02:12 PM
70-442-W30's Avatar
344879M363895
According to my wife's grandpap, the 442 also needs a water pump. Thing is the one that's on there looks like the newest item under the hood. So, I'm thinking it is possible that it has been replaced. I looked for the "X" on it and did not find, so that means that this isn't original right?
Took tons of pics of what I could get to:
Old Feb 1, 2016 | 05:51 PM
Octania's Avatar
Lack of ID marks indicates aftermarket pump
You can also use the somewhat more common "O" 400___ water pump in that application, or get another generic like you have now.
Old Feb 1, 2016 | 06:01 PM
tru-blue 442's Avatar
Old School Olds
Here's one.
Old Feb 1, 2016 | 06:04 PM
70-442-W30's Avatar
344879M363895
So how do I know this one is good or bad? Just eventually get it going and test for leaks and temp. rise? Is it easy to change out? Doesn't look bad to me except for that fan in the way.
Old Feb 2, 2016 | 12:01 PM
stan 65 cutlass's Avatar
usually they leak from the snout, there is a small hole on the underside of it. or if its loose with a bad bearing, but if neither and its not noisy then i would leave it on
Old Feb 2, 2016 | 12:29 PM
70-442-W30's Avatar
344879M363895
Thanks for the info. I'm looking forward to getting this car moving. Got a new fuel tank yesterday and it needs filled up.
dnmfranco
Aug 9, 2013 07:09 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
Kidcutty
Jun 17, 2010 07:48 PM
72Ctlss
Jun 23, 2009 03:12 PM
silverriff
Jun 9, 2008 02:43 PM
