WTF 04b will not accept quadrajets ..?
Old Nov 20, 2010 | 04:39 PM
davepnola's Avatar
Can it be modified , the whole point of me buying this intake was to look as close to a w30 look and using the air cleaner .... ? I really do not want to use. A spacer , do I have any options ? Thanks
Old Nov 20, 2010 | 08:12 PM
rocketraider's Avatar
Oldsdruid
Did you get the spread-bore or square-bore version? If you got a square-bore, you'll have to use a Holley or AFB unless you get an adapter spacer.
Old Nov 20, 2010 | 09:12 PM
Run to Rund's Avatar
Put a qjet gasket over the holes and see if you can bore out the manifold and still have enough meat to seal the gasket, and that the carb base has meat in the same areas.
Old Nov 21, 2010 | 12:20 AM
davepnola's Avatar
I will try to modify looks like u can , might as well match port while there , any other secret mods on this intake any one can share , thanks again
Old Nov 21, 2010 | 05:39 AM
Yes, there should be enough metal left. Edelbrock used one casting and varied the final machining to make both Qjet and square bore versions.
Old Nov 21, 2010 | 06:15 AM
Rickman48's Avatar
I once match ported a Torker with hand-files, as I didn't want to wait!
The secret to working aluminium is to use WD-40 to keep files or anything with 'teeth' from clogging up!
I also have a 'file brush' handy.
Old Nov 21, 2010 | 07:24 PM
507OLDS's Avatar
I have machined these before.There is plenty of material to do it.
halfmoontrail
May 31, 2013 05:41 AM
1970_442
Mar 2, 2012 05:49 PM
ijasond
Aug 26, 2009 05:37 AM
Olds64
Feb 14, 2008 07:19 PM
