It wont start
Old Aug 4, 2010 | 08:23 PM
1970_442's Avatar
It wont start
my 455 ran the other day. for 7 seconds. then i tried again the next day and it ran for about a minute. i know it's getting fuel, and it has compression. i just replaced the spark plugs. i know the coil is getting power and ive tried two distributors (i don't know the condition of either). ok any ideas
Old Aug 4, 2010 | 08:42 PM
Blk71SX's Avatar
too much fuel maybe?
Old Aug 4, 2010 | 08:57 PM
jrsixx's Avatar
Are you getting good spark from the coil? And to the plugs? If I had to guess, first guess would be a bad coil.
Old Aug 5, 2010 | 05:27 AM
70 cutlass s's Avatar
Did it run longer before you did the tune up. If not, have you changed the fuel filter. Even if its getting fuel the fuel pump could be going bad.
Are you running points or HEI. If you have points check them out. If HEI check the control module. If they are good then I would be looking at the fuel pump.
Could have a hole in the fuel line causing it to suck air instead of fuel.
The other thing would be a bad ground.
Old Aug 8, 2010 | 12:44 PM
d2_willys's Avatar
I would check the fuel pump, fuel filter, and also the gas cap. The gas cap may need to be vented. You may also have a problem with needle and seat on carb. Ignition problems are usually all go or no go, not sometimes.
Possibility of gas contamination???
Old Aug 11, 2010 | 11:20 AM
1970_442's Avatar
ok i replaced the coil points and condenser. the coil is getting power. its getting fuel. fuel is good. it is NOT getting spark. i dont know why i also have gotten it down to the distributor, so something is wrong there but i dont know what. this is really starting to frustrate me
i did take the number one plug out turn it over to when it would fire held it against the block with power to the coil and nothing, but if i held it to the block first and then out power to the coil it would spark
this is out of the car btw
Old Aug 12, 2010 | 08:01 AM
Warhead's Avatar
WAG....
No/bad ground wire.
Jim
Old Aug 13, 2010 | 09:30 AM
svnt442's Avatar
You did hook the points wire to the negative side of the coil, correct?
1973_442
Mar 22, 2007 05:42 PM
68oldsrocket
Dec 19, 2006 07:20 PM
monsterpuff
Oct 17, 2006 02:56 AM
monizrage
Aurora
Aug 13, 2006 01:24 PM
J'ville
Jun 10, 2006 03:13 PM
