wiring diagram for Olds 371 from distributor to plugs
Old Aug 21, 2016 | 10:12 AM
Sid's Avatar
Sid
I need a wiring diagram showing me what plug wire goes where on my 371 distributor, been working on car draft tube and got some wires loose on the distributor thought I had them back in the right spot but guess not, hope you can help. Thought I had a diagram cant find.
SID
Old Aug 21, 2016 | 04:02 PM
Tedd Thompson's Avatar
Firing order should be cast into the top of the intake manifold. If it hasn't been messed with #1 plug is first hole front left drivers side and remember that the distributor turns counter clock wise that should get you there.. Tedd
Old Aug 21, 2016 | 05:16 PM
I'd find #1 tdc on the compression stroke by pulling the spark plug and where the rotor is pointing to is #1 and go from there.
Old Aug 21, 2016 | 06:20 PM
Charlie Jones's Avatar
Phantom Phixer
Here's what you're looking for;
Old Aug 22, 2016 | 07:12 AM
And again, the location of the No. 1 plug wire on the cap depends on where the distributor was installed. If the distributor has ever been out once the car left the factory, you MUST verify that No. 1 cylinder is at TDC on compression.
Old Aug 23, 2016 | 05:09 AM
Sid's Avatar
Sid
Thanks for all the help ,had number 2 and number 8 crossed.
SID
MrGasser
Sep 23, 2015 07:42 AM
bob p
Apr 10, 2015 01:55 PM
buster hyman
Oct 2, 2013 01:42 AM
papadoc
Apr 27, 2008 11:01 PM
