Will a 455 from a '73 98 fit in a Cutlass?
I just meant something from the late 60s-early 70s. I found a 98 and was thinking about buying it and keeping around until I find a recipient Cutlass.
Every single Olds V8 from 1964-1990 is dimensionally identical externally except for the deck height differences from small block to big block. Motor mount holes, crank centerline, and bellhousing bolt pattern are all exactly the same on every single one.
Used 98's
ok question was originally can a 455 out of a '73 98 get put into a cutlass? yes easily under the following conditions... the engine mounts are the same on any V8 olds like say a cutlass... any originally v8 equipped olds after 1963 already is set up to receive the motor no problem with no difference between the big blocks (400,425,455) and the small blocks... olds made them the same for mountability purposes... the original 455 that would come in a 1973 Olds 98 would not have a manual so it would have heads set up for Auto so if car you are transferring to had an automatic then you could swap it easy and could take the tranny with it but if you desire a manual then the block could be used but head would need swap out or would need alteration to use and as I mentioned if you wanted to hook up AC then no problem just hook it into an existing system (i.e. hoses, blower/electrical connects ect.) same goes for power steering pump ... if no AC then you have to cap any water hoses and you have a very heavy compressor still on engine which you either don't run a belt and just leave it there or you take it out but since the motors are externally balanced with the alternator, AC compressor, another optional piece was power steering pump all evenly balanced around engine for weight distribution with different mounts for all of them but if you transfer motor into a car with no AC or no power steering you are either keeping the pump and compressor on or getting new mounts for other components left like mounting alternator on other side... I had to do it on my post coupe 67 442 I used to have when I grabbed a nice 455 W30 engine out of a 70 442 manual (F heads) and AC/Power steering that had a smashed rear... I went to alternator only set-up to save weight... went really well with my M21 manual equipped tranny with competition clutch and the 3.90 posi 10 bolt rear... extremely fast but it had AC and power steering so to get rid of that extra 100 pounds I removed them but had to move altenator re-bracket and redo belting cap/remove hoses...but back to the question at hand... the 73 98 would have come with 455 with the AT so had Ka Heads, not sure what mods would be needed to use in some olds manual cars but they specifically ran J heads that year in manuals... why make a different head if they were interchangeable easy ... so the real question is...why buy a big piece of real estate like a detuned 73 land yacht like the 98 if you don't like it on its own merits as a keeper just for a commonly available 455... and take a usable 98 cheap from an entry level guy off the street for a car you don't own yet or may never have... buy the type car you want... even if incomplete to get starting point and build off that maybe the car you get will have a big block already that just needs love
... waste a lot less money being model specific and collect less clutter trust me... clutter enough gathering stuff you need to replace
The pivot ball I can see, but then a hyd set up fixes that, Do the later blocks have the mount just not drilled/machined, or total different casting?
Did they drill all cranks for a manual pilot bushing/bearing? or is that an issue when going auto to stick?
I have no idea where you got this information. The "regular" 455s from 1973-1976 had J heads and the performance applications had K heads, along with a lot of industrial engines (irrigation), jet boats, and they were also used as service replacements. And it didn't really matter what transmission was used.
Again,
http://wildaboutcarsonline.com/cgi-b...=9970399476565
the point is and continues to be buying a running car as a parts car before you have a good car that may or may not be able to use it's engine unmodified... is silly unless the 98 is desireable enough on its own merits... 98 takes a person who really wants that big a car... as a parts car they are very limited...that motor would be fun in an AT 73-77 Omega set up for V8 and could use the AC as a lot of them left came with AC vents blower and power steering... everything would bolt right in with a squeeze... but not many left... I say buy what you want and buy the parts car later... again
all the AT '73 455's got KA heads... as well as the crank issue
again the guy wants to decide wether he should buy this 98 for a car he doesn't have... and there is another reference that has more accurate info would love to check it out... but have used it for referral on heads before and has been on the money... and had good engine code one too...
Think about that for a while and consider which is more likely: GM switched their entire manufacturing operation, or someone posted incorrect information on the internet.
So what have you decided to do? Is the 98 a driver or just a parts car? if parts car, I`d be interested in body. As for Drilling the crank, just use the correct pilot bushing as the crank is already recessed for the torque converter. Don`t worry about the different heads as the 455 will ****** the lighter body like it is. I have one in a 72 c-10 and also in a 83-88 Royale --bone stock-- they do the job.
tmaleck
Aug 15, 2021 08:17 AM
STR-8_CHARGIN
Aug 13, 2010 04:43 AM
