when did the 455 change pistons?
Old Jun 19, 2009 | 07:11 AM
MN71W30's Avatar
Is there a piston dish difference between 1971 455 and a 1974? I remember reading once that the compression was changed by opening the head chambers after 73 so they used a less dished piston. I was thinking that I could throw on a set of 80cc E heads and end up with a better compression ratio than 8.0. Any truth to this?
Thanks for any advice.
Old Jun 19, 2009 | 08:40 AM
citcapp's Avatar
Lots of good information in the "tech" forum in the heading at the top of the page
In general terms the engines before 1971 had the higher compression with small dish pistons. Later versions had deeper dishes dropping the compression to around (8.0 to 8.5) Most of the heads have 80cc with a few exceptions D heads were smaller but these heads are rare and command high prices 2k+ or you can go to Edelbrock allumimun heads 77cc.
Best buy is aftermarket pistons and C big valve heads for better flow
Just my opinion
Old Jun 19, 2009 | 09:26 AM
With the exception of the 1968-69 "D" heads, all BBO heads have the same 80-ish CC chambers. The size of the dish was what determined the CR. Different dish sizes were used from 1968 through 1976.
Limey
Apr 15, 2013 10:45 AM
dre
Drivetrain/Differentials
Aug 31, 2011 11:04 AM
tuellbox
Dec 18, 2007 04:54 PM
shaks 442 clone
Jul 29, 2007 09:27 PM
