What are th elimits of the stock valve train?
Old November 27th, 2010, 07:49 AM
Joel's Avatar
Can I safely run a cam with .475 lift and springs with 90# closed and #280 open thru the stock rockers, stands and pushrods?
Not a high rpm moter, just a street criuser.
Thanks, Joel
Joel is offline
Old November 27th, 2010, 08:07 AM
InfoJunkie
InfoJunkie's Avatar
Yes you can. Check the tech section on camshafts and on valvetrain geometry for more info.
InfoJunkie is offline
Old November 27th, 2010, 02:40 PM
I bleed Oldsmobile
BIGJERR's Avatar
Why not invest $300 in a Comp Cams kit and be done with worrying about it......My .02$...............Jerr
Also I would say yes it should be all right.......
BIGJERR is offline
Old November 27th, 2010, 03:04 PM
Joel's Avatar
Thanks for the reply's. I'll have to check out the comp kit. What do you get?
Joel is offline
Old November 27th, 2010, 03:22 PM
InfoJunkie
InfoJunkie's Avatar
Depends on the kit.http://www.compcams.com/#
Old November 27th, 2010, 03:29 PM
Oldsmaniac's Avatar
Thanks, Joel
For sure, before all this aftermarket stuff came out I built a 425 that would rev to 6500 without a miss. Cam was 590 lift stock valve train with adjustable pushrods. That was in 1977 and the engine is still runnable and intact.
Oldsmaniac is online now
vettemad
June 30th, 2010 06:57 PM
66ninetyeightls
April 23rd, 2010 05:48 AM
Oldwolf
November 17th, 2009 07:48 AM
TWS
January 10th, 2009 02:50 PM
blawton442
November 30th, 2008 05:20 AM
Quick Reply: What are th elimits of the stock valve train?
