What are th elimits of the stock valve train?
Old Nov 27, 2010 | 07:49 AM
Joel's Avatar
Can I safely run a cam with .475 lift and springs with 90# closed and #280 open thru the stock rockers, stands and pushrods?
Not a high rpm moter, just a street criuser.
Thanks, Joel
Old Nov 27, 2010 | 08:07 AM
InfoJunkie's Avatar
InfoJunkie
Yes you can. Check the tech section on camshafts and on valvetrain geometry for more info.
Old Nov 27, 2010 | 02:40 PM
BIGJERR's Avatar
I bleed Oldsmobile
Why not invest $300 in a Comp Cams kit and be done with worrying about it......My .02$...............Jerr
Also I would say yes it should be all right.......
Old Nov 27, 2010 | 03:04 PM
Joel's Avatar
Thanks for the reply's. I'll have to check out the comp kit. What do you get?
Old Nov 27, 2010 | 03:22 PM
InfoJunkie's Avatar
InfoJunkie
Depends on the kit.http://www.compcams.com/#
Old Nov 27, 2010 | 03:29 PM
Oldsmaniac's Avatar
Thanks, Joel
For sure, before all this aftermarket stuff came out I built a 425 that would rev to 6500 without a miss. Cam was 590 lift stock valve train with adjustable pushrods. That was in 1977 and the engine is still runnable and intact.
vettemad
Jun 30, 2010 06:57 PM
66ninetyeightls
Apr 23, 2010 05:48 AM
Oldwolf
Nov 17, 2009 07:48 AM
TWS
Jan 10, 2009 02:50 PM
blawton442
Nov 30, 2008 05:20 AM
