What size motor is it?
Old April 17th, 2011, 12:30 AM
Theo's '67's Avatar
Hey fellas. Ive got a '67 Delta 88 Conv. i was wondering how do i tell what size motor is in it. It has a 2bbl sitting on top?
Theo's '67 is offline
Old April 17th, 2011, 01:45 AM
svnt442's Avatar
It SHOULD be 425, but either tell us the numbers or take a picture of the shelf above the water pump so we can see it and then tell you what you have.
svnt442 is offline
Old April 17th, 2011, 06:40 AM
jaunty75's Avatar
Nice-looking car you've got there!
I've got the exact same car with the 425 engine and the same carburetor as yours. The numbers on the shelf above the water pump confirm the engine according to the codes on this page:
http://tech.classicoldsmobile.com/36.shtml
My numbers are 389244D where the D is larger than the other characters.
These numbers should be easy to find.
jaunty75 is offline
Old April 17th, 2011, 03:33 PM
Theo's '67's Avatar
Yes i found it! And it is the same As Juanty75's. That helps alot with finding parts. Thank you for all your help. I have seen you car all over the internet. How long have you had it. It is beautiful. I have been thinking of changing to 4bbl. Any thoughts?
Old April 17th, 2011, 03:46 PM
jaunty75's Avatar
I haven't really considered it. I rebuilt the carb that's on the car, and it runs like a top and has plenty of power. I sort of feel that I don't want to fix what ain't broken.
I've had the car since June of '09, so almost two years now. It doesn't look half as good as yours!
jaunty75 is offline
BLACKCADDY
June 2nd, 2015 09:38 AM
willys33
December 27th, 2012 01:08 PM
Wildcard
December 9th, 2012 10:35 AM
Eddie Hansen
September 10th, 2012 01:12 PM
ctrain22
May 20th, 2009 11:02 PM
Quick Reply: What size motor is it?
