what rocker studs 2 use 70 stock E heads
Old Jan 9, 2011 | 02:00 PM
sx455raidercelticfan's Avatar
hi every1 my heads are in the shop gettn milled down for guide plates and rocker studs, does any 1 know the exact part number of rocker studs i need?? im going with 7/16 harland sharp rockers, i looked online and theres 2many different oldsmobile part numbers 2 choose from, i dont want 2 spend $150 arp's thank you
Old Jan 9, 2011 | 06:04 PM
cutlassefi's Avatar
Why not get the 5/16x3/8 studs. How much spring pressure are you going to have? Most applications will be fine with the Comp Cams style conversion. Otherwise I don't think you can find 7/16 studs without tapping the existing holes. Again depending on the application not sure it's worth it.
Jmo
Old Jan 10, 2011 | 12:40 AM
LOL!!!!!!!! i was just gettn ready 2 email you 2 ask witch 1s to use, if you say get 5/16x3/8 thats what ill get!!! you know more about the spring pressure than i do these heads are going 2 have the springs your sending me and the roller cam your grinding so what ever you recommend is what ill use!!!! do you know the part number of the correct rocker studs 2 use for stock e heads??
my PP damper just came it sure is nice for 200 shipped i just ordered another 1 and im sending back the 600 one i bought for my other motor, thanks again for all the guidance mark!!!!
Old Jan 10, 2011 | 08:43 AM
507OLDS's Avatar
I have done heads either way,and you don't need to mill the pads for guide plates.You could just leave them alone,and use the Harland Sharp shaft rockers.No guide plates,machining,or special treated pushrods needed.
Old Jan 10, 2011 | 12:57 PM
cutlassefi's Avatar
I'll get you the part numbers, just pm'd you. All your stuff will leave Erson tomorrow.
Mark
import extermination
Dec 28, 2013 06:25 PM
Apr 19, 2012 10:38 AM
Delmont 88 PA
Mar 21, 2012 04:52 PM
CutlassLegend
Sep 21, 2011 02:56 PM
defiant1
Mar 31, 2011 04:28 AM
