What oil to run?
Old Jun 24, 2015 | 04:18 AM
Dbechtel71's Avatar
What oil to run?
Hello again just curious as to what brand and viscosity oil I should be running in my 70 455. It's a bit above stock mild cam and bored.
Old Jun 24, 2015 | 05:29 AM
Due to catalytic convertors and roller systems oils have gone through some changes. What works on late model cars will not work on our old flat tappet cam engines. I use Valvoline 10w-30 VR1 for street use and Wix filters. Others will chime in with their suggestions.
Heres a good read:
https://540ratblog.wordpress.com/
Old Jun 24, 2015 | 08:04 AM
Rallye469's Avatar
I'll second the VR1.
-Pete
Old Jun 24, 2015 | 10:58 AM
Dbechtel71's Avatar
Sounds good! I can get that at any parts store? Advance auto AutoZone?
Old Jun 24, 2015 | 01:43 PM
The 10w30 is not stocked by a lot of parts stores you may have ask if they will get it from their warehouse.
Old Jun 24, 2015 | 01:54 PM
Intragration's Avatar
x3 on VR1, although I can't figure out why everyone stocks 20W50 and straight 50, but not 10W30.
Old Jun 24, 2015 | 08:35 PM
I'm not familiar with VR1. Does it contain ZDDP?
Old Jun 24, 2015 | 08:47 PM
Yes, Valvoline Racing Oil in the silver container, do not use the not for street use as it is strictly for short term racing use.
Old Jun 25, 2015 | 04:59 AM
Destructor's Avatar
No one carries VR-1 non racing oil around here anymore, which pisses me off.
Old Jun 25, 2015 | 05:04 AM
tru-blue 442's Avatar
Old School Olds
I get mine from Napa, 30 wt. in the summer, 10-30 in the winter.
Old Jun 26, 2015 | 06:40 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I see VR1 20W50 at Walmart here, silver bottle but SM rated. I buy Quarter State Defy,5W30 SL rated and ZDDP and tests done have been good.
Old Jun 26, 2015 | 09:25 AM
Ozzie's Avatar
Vernon might get chilly in the winter. In 1970 Olds was recommending 20W, 10W-30, 10W-40, & 20W-40 from 20F & up. And they said 10W, 5W-30, 10W-30, & 10W-40 from 0F to 60F. So if you want a "year round" oil the 10W-30 or 10W-40 would seem like good choices, as has been suggested. They also said that the SAE 5 based oils (single or multi viscosity) are not recommended for sustained high speed driving.
Probably most reputable brands would do the job as long as the zinc level is maintained high enough for the flat tappets. Sometime figuring that out is a challenge.
Old Jun 26, 2015 | 05:42 PM
Gary M's Avatar
Not to dis any other recommendations I use Bad Penn oil for classic cars only because my builder recommended it. To each his own but make sure it has what your motor needs. Jiffy Lube will not work!
Old Jun 26, 2015 | 06:11 PM
ziff396's Avatar
I ran the expensive oils, Royal Purple etc in mine. Tried 20/50, 10/40, and now I am running VR1 10/30. Actually my oil pressure with a high volume pump is better. 50-60 cold, 20-25 hot idle. Used to run 45-50 cold and 15-20 idle. Go figure?
Old Jun 28, 2015 | 12:31 PM
jpc647's Avatar
I've been using Accel 10w-40 as of lately. It was available at Walmart for a while, as of the last couple weeks I haven't seen it. It's SF rated, and guaranteed to have at least 1100ppm of ZDDP.
The best part, it's not a boutique oil, and therefore isn't $8 per quart. It's like $3. The one UOA I did on it was better than the the Molbil Clean 5000 I had in it before.
I also only have a 72 Cutlass with a 350, so it's not a race car. I can't fathom the $8+ a quart for Joe Gibbs, etc.
Old Jun 28, 2015 | 12:35 PM
lemoldsnut's Avatar
10 30 vr1 here too. My local parts store carries it and if out of stock can get it in one day like almost any other part.
Old Jun 28, 2015 | 01:56 PM
The_Jeremiah's Avatar
I am very partial to the VR1 and delo 400, which you can get in 15w-40 and 30, its a lot cheaper, I have since gone delo and have no problems. oil pressure is a lot more consistent
Old Jun 29, 2015 | 01:04 AM
rustyroger's Avatar
'87 Delta 88 Royale
A lot of people think a thick oil gives better protection than thinner ones. So they buy 20w50 and feel good about their engine.
If you have a worn old engine with loose bearing clearances then 20w50 might be just what you need, but if you have an engine in good shape, particularly if it has a re-ground crankshaft, then 5w30 or 10w40 is more likely to be best. Oil needs to be thin enough to get everywhere it's needed in a hurry from a cold start.
Roger.
Old Jun 30, 2015 | 04:41 AM
Dbechtel71's Avatar
Wow thank you all for the replies. A lot of ideas
Old Jun 30, 2015 | 04:56 AM
Junkman's Avatar
This article was originally written for the Corvair, however, it contains a lot of information about oil that is pertinent to the old car hobby. Worthwhile reading if you have the time, because it was written by an oil engineer, and goes into great detail about oil then and now.
The full PDF version: http://www.widman.biz/uploads/Corvair_oil.pdf
The quick and brief condensed version:
http://www.widman.biz/Corvair/English/Links/Oil.html
Old Jun 30, 2015 | 05:59 AM
Good read
Old Jun 30, 2015 | 06:40 AM
I don't think I've seen that article before. Looks thorough.
I'll have to take the time to read it.
Thanks.
Old Jun 30, 2015 | 12:51 PM
bigbog442's Avatar
Oil
I use only full synthetics in my oldsmobile. I use to use 5/50 and 20/50 depending on the time of the year. It was getting to hard to find so now I get the 10/30. it the Castrol Edge
Old Jul 6, 2015 | 09:29 PM
buzzbomb's Avatar
I have and a lot of my friends always used the shell rotella 15w40 on our built engines with no additive before the oil manufactures cut the zinc in the oil. I now use rotella 15w40 with a bottle of lucas zinc additive and no problems . Even the new rotella has a touch more zinc that the other regular oils.
Old Jul 7, 2015 | 04:04 PM
Destructor's Avatar
The local Auto Palace now carries VR-1 again, just bought 5 quarts, I will buy one quart every time I go in to stock up. To bad I changed the oil about 2 months ago.
shamusj
Mar 4, 2016 06:48 AM
gabe442
May 25, 2012 06:27 AM
65OldsDelta88SuperRocket
Jan 5, 2012 08:22 AM
awspeich
Nov 30, 2006 07:28 AM
