What to most Olds peak out at?
From what I know, 4-4500 stock. Mine isn't stock and has run 6300 a few times still pulling. This year I plan on 5k max to make her last.
The project in question has a Th400 and axles geared at 6.17:1. Based on the tire specs the motor will be turning 50.88 RPM's for every 1mph in this vehicle. 95% of my driving will be city stop and go at a max of 45MPH (2289rpm's). Maybe 55 or 60 when out of town. I am trying to get an idea of how badly this thing will suck the bottom of the gas tank out at such speeds. If my numbers are correct the truck should be able to do a max of 55mph to retain any sort of fuel economy. I believe this is called the "power band". It's that sweet RPM range where the motor is at it's best in both power and fuel economy.
Even though the motor has enough power to push the truck to 85+mph EASILY. The rest of the vehicles drive line was never designed to move above 58mph. Plus, anything above 60 or so and I'll bet the 455 gets MIGHTY thirsty.
See this link for torque and HP curves for 1970 stock engines.
http://wildaboutcarsonline.com/membe..._Specs_1-3.pdf
The same motor seems to make just under 500 pounds of torque at about 3,400 RPM.
sx455raidercelticfan
March 21st, 2023 08:37 AM
david55838
June 16th, 2015 05:27 PM
