what have we here
Old May 23, 2012 | 08:20 PM
805cut's Avatar
what have we here
started to clean up the crank i got with my 455 block an noticed some holes drilled 4 of them the first ones filld to the top with weld the seconds empty but runs fairly deep the thirds about 3/4 filled wth weld and the forth ones drilled about half way in all four are in a row to the left side of the crank.. i know this has to do with balance obviously but why and when would someone do this?
Old May 23, 2012 | 09:14 PM
67 Cutlass Freak's Avatar
You are correct. This was done during the ballance process. Those are from heavy metal slugs, not weld. It's pretty expensive. If your not going to use the same pistons, balancer, and flexplate, you should have it reballanced anyway.
Old May 23, 2012 | 09:33 PM
805cut's Avatar
deff not useing the same pistons, thanks for the reply!
67grandsport400
Jan 22, 2011 10:32 PM
bluechevelless
Jun 1, 2010 06:06 AM
GoodOldsGuyDougie
Feb 20, 2009 11:58 AM
egknz
Nov 21, 2008 06:10 PM
shash'71cut"S"
Oct 5, 2008 07:18 AM
