What gaskets do you guys recommend ?
Old Feb 21, 2013 | 08:00 AM
squirell's Avatar
Govt slave
Dropping a 455 into my 67 Cutlass.
Not taking the engine apart,but going to detail and change out
oil pan,exhaust manifold (stock repops from thornton) ,water pump,thermostat and valve cover gaskets.
Any recommendations on gasket companys ?
Old Feb 21, 2013 | 09:31 AM
covertolds's Avatar
For what you are doing, it's hard to beat Fel-Pro. You might as well do an intake gasket and a new timing chain and gears. Timing cover gasket and seal also.
Old Feb 21, 2013 | 04:55 PM
Lady72nRob71's Avatar
I have had good luck with fel-pro for years. I like the thick rubber ones for the valve covers.
Old Feb 21, 2013 | 05:56 PM
jfb's Avatar
jfb
I would suggest cometic or detroit for head gaskets and super sealing purposes like high compression or super charging plus nitrous.
Old Feb 21, 2013 | 06:00 PM
x2
Old Feb 21, 2013 | 06:03 PM
If you pull the heads consider milling them at least the differance in head gasket thickness. The factroy steel shim gasket measure .017 inch, the Fel-Pro are .045 (I think).
Old Feb 22, 2013 | 07:47 AM
RonFX's Avatar
gaskets
Guys:
Always use Fel Pro, the BEST gaskets money can buy. I have used and sold them for many years w/ no problems at all, their customer service is also second to none. They have a performance line that uses all the latest and greatest ideas and materials on the market.
Thanks Ron
Old Feb 22, 2013 | 05:36 PM
BILL DEMMER's Avatar
Just the facts...
i read on here, the diesel oil pan gasket is the better choice due to it's steel core.
bill
Old Feb 22, 2013 | 08:11 PM
Redog's Avatar
I like the Fel-Pro as well. That's all I use on both my cars.
I like the reusable ones for the valve covers. I'm not as old school as other guys, maybe that's why I don't care for the cork gaskets
Old Feb 23, 2013 | 07:09 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I can remember back in the 60's that I wouldn't use anything but Victor gaskets. Fel Pro was around then but did not fit well. I just binged them and they are now an Indian company. My how times change.
Old Feb 24, 2013 | 06:46 AM
squirell's Avatar
Govt slave
Fel-pro it is...thanx guys
jag1886
Mar 17, 2018 12:12 PM
Tedd Thompson
Jul 6, 2015 06:30 AM
70CCV
Jan 17, 2015 07:44 PM
motor
Oct 2, 2013 04:27 PM
Dave Siltman
Nov 18, 2011 03:14 AM
