What is this engine, and what is it worth?
Old Nov 6, 2013 | 03:10 PM
rustynails's Avatar
This engine came in a Chevy truck that I bought (obviously not original to the vehicle). Can anyone identify it, or tell me where to look for casting/ID numbers? Also how much would it be worth in parts, if I part it out? Or is this just worthless scrap??
Old Nov 6, 2013 | 03:58 PM
gearheads78's Avatar
car guy
Not much. 4A heads tell me its more than likely a late model motor worth scrape value.
Old Nov 6, 2013 | 06:59 PM
Kennybill's Avatar
See if it "says" 403 on the side of the block.
Old Nov 6, 2013 | 07:25 PM
car guy
I was thinking 5a so 4a will have come on a 403 but still with the windowed mains I would not plan on making any kind of real hp with it. Might be OK for a mild build. Does it turn over at all?
Old Nov 6, 2013 | 08:32 PM
Redog's Avatar
4A heads. More than likely a 403. Very large CC heads too. as large if not larger CC than BBO heads.
Casting numbers between the timing cover and manifold will tell us for sure. Anybody could have swapped the heads for 4A
I see point distubtor, and a late 60's Alternator bracket, bypassed heater valve and late 70's blue valve covers. I also see a blocked off EGR port
Old Nov 7, 2013 | 06:44 AM
I'm guessing this truck originally came with an Olds diesel. Check the VIN to be sure. If so, I'd be interested in the motor mounts.
Old Nov 7, 2013 | 07:50 PM
rustynails's Avatar
The numbers in front of the intake are 557265-4B. Can anyone decode them?
Old Nov 7, 2013 | 08:10 PM
Google can.
It's a 403.
Old Nov 7, 2013 | 08:35 PM
2blu442's Avatar
But if you do send it to the melting pot first remove the bolt on items. Alternator bracket, pulleys, distributor, oil pan, exhaust manifolds, timing cover, etc... these things will interchange with older engines that are in more demand. Might as well take a half hour to get maybe another $100 more than just scrap metal.
And Joe already has expressed interest in the motor mounts.
Old Nov 7, 2013 | 09:56 PM
rustynails's Avatar
Thanks guys, for shedding some light on this. What other engines are the bolt-on parts compatible with?
Joe - I don't think I can help with the mounts... This was in a '61 Chevy 4x4 pickup, definitely not a diesel.
Old Nov 8, 2013 | 08:07 AM
2blu442's Avatar
Most of the bolt on parts will fit 330, 307, 350, 400, 425, 455. The exhaust manifolds will bolt on the big blocks but not flow as well. The oil pan too will bolt up but is slightly different than what was used on the big block. Pretty much the rest will fit on all of the engines listed above. John
Old Nov 9, 2013 | 09:59 AM
Lars's Avatar
the crank may be drilled for a stick, I think they all were, its lighter than earlier cranks, someone may want it.
Old Nov 9, 2013 | 12:55 PM
svnt442's Avatar
Huh? No 403 cranks were drilled for a pilot bushing. That's one of the reasons that all of the 4 speed T/A's came with the Pontiac 400.
And I don't believe that a 403 crank is any lighter than a 350 crank. As a matter of fact is should be a tad heavier due to the added weight needed in the counter weights because of the heavier pistons and rods used.
Old Nov 9, 2013 | 02:24 PM
Lars's Avatar
Well randy, the Guy wants to know what to look for. We don't know whose been in that motor last. So the correct awnser would be... Ya most 403s didn't come with a drilled crank. But check if it's drilled, cause ya never know!
Old Nov 9, 2013 | 03:16 PM
svnt442's Avatar
Actually no 403's came with a drilled crank. AFAIK they only put a stick behind 2 Oldsmobile engines after 1976. The gas 260 and the Diesel 260. And that was a VERY weak 5sp trans.
Old Nov 9, 2013 | 06:56 PM
64Rocket's Avatar
I have two 403 engines and both have a drilled crank for stick shift.
Gene
Old Nov 10, 2013 | 06:17 AM
Kennybill's Avatar
The blocks I have do not have the z-bar pivot ball bung. One could make a bracket off bell housing or hydraulic clutch. I would keep the block. Jmo, Ken
Old Nov 10, 2013 | 06:49 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
If in decent shape throw early 350 heads on it and have fun. Any Olds will be better than any stock sbc in a truck, even a good 307. Those brackets will fit any of SB Olds 260-403. Some including the pulleys, depending on water pump, will work with 400-455 too.
Old Nov 10, 2013 | 07:29 AM
Lars's Avatar
Pull the pan and look for SMW
Old Nov 10, 2013 | 09:34 AM
Kennybill's Avatar
I'm a 403 fan. Love those huge bores, great for value unshrouding. Don't worry about webbed mains for street/strip. Mine never overheated. Jmo, Ken
Old Nov 11, 2013 | 06:02 PM
64Rocket's Avatar
I check the two 403 blocks i have, both have the "Z bar" pivot bolt hole.
just saying
Gene
Old Nov 12, 2013 | 11:20 AM
oddball's Avatar
403's can be built well. I know, I'm running one! Save the block for someone that wants to run it. The rest is (IMO) junk.
Old Nov 20, 2013 | 03:56 PM
rustynails's Avatar
Thanks guys, if anyone needs any parts just let me know. I'll hang on to the block for a few months in case anyone wants it, then it will be melted down to make a new Toyota!
Old Nov 21, 2013 | 06:59 AM
507OLDS's Avatar
As for the crank thing,there weren't as many stick shift cars in the later years,but for whatever reason,Oldsmobile started drilling more cranks for the pilot bearing.The smogger engines have always been a good source for stick cranks.All of the 403's that I have owned,came with drilled cranks.Made a nice stick-shift G-body with one too.
The TA's did have the 400 Poncho for the sticks,and the 403 Olds for the autos,but it wasn't because of the crank.
Old Apr 7, 2014 | 05:35 PM
83-425's Avatar
call me on selling the moter I have some questions 443-326-5000 steve
Old Apr 7, 2014 | 07:15 PM
Octania's Avatar
Ha ha ha
it's the _4B_ block, sir
The SMW 403's "might be" of the 4A block casting ID, remember? Page 12!
If it turns over, use it.
Cam, AL intake, and an HEI
Check that distributor, google the number, sometimes you get lucky and find a rare and valuable one.
The #16 EGR intake is $5 worth of scrap, unless you are an optimistic epay seller, then it's $1more.
http://www.ebay.com/itm/OLDSMOBILE-4...e07e55&vxp=mtr
Old Apr 7, 2014 | 07:23 PM
Steve, this thread is from 11/2013. You might see if there is a more recent post if your looking for an engine.
scharpp
Oct 8, 2014 05:55 PM
gbledsoe3
Aug 15, 2014 05:18 PM
805cut
May 3, 2012 08:11 PM
mcutlass1969
Jan 9, 2012 07:42 AM
eke82
Ninety-Eight
Dec 14, 2006 05:40 PM
