455 efi conversion
Old Aug 17, 2011 | 09:06 AM
hessdawg's Avatar
455 efi conversion
started with some tech drawings
measured fuel rail drill points
drilled fuel rail pilots
set up intake on drill
all drilled out
epoxying the bungs in
grind and re-epoxy underside
checking to see if i have room with a 2 inch spacer
tapped up for paint
por 15 black sprayed
por15 engine enamel aluminium
Old Aug 17, 2011 | 09:23 AM
66ninetyeightls's Avatar
Land Yacht Captain
Nice.
Thats a great deal of work. Was there a reason you chose to build it from scratch instead of purchasing a manifold and fuel rail premade for this?
Old Aug 17, 2011 | 06:41 PM
hessdawg's Avatar
the first reason was money
china knockoff $250-$300 fuel rail kit is $200-$250
second the injector angle sucks on all the pre made stuff
Old Aug 17, 2011 | 09:33 PM
nonhog's Avatar
Registered car nut
Awesome! Engine specs? Whats it going in?
Old Aug 17, 2011 | 11:47 PM
hessdawg's Avatar
old 455 bored 30 over 9.5to 1 compression. forged rods and pistons. all the casting numbers were ground down on the heads so I have no idea what they are. nodular crank. gotta get cam specs. port matched intake and heads. magnum rockers, jomar stud gurdle headman headers.
its going in my 78 trans am
Old Aug 18, 2011 | 05:55 AM
gearheads78's Avatar
car guy
Nice!! What system are you using to drive it?
Old Aug 18, 2011 | 06:16 AM
507OLDS's Avatar
Do you have to run the spacer so the linkage clears the rails?
Have where does the tip of the injector sit in the runner.If it is up inside the bung,you need to move it down.Otherwise it will spray the barrel of the bung,then drip down into the runner.You want the tip of the injector to be flush with the roof of the runner.Looks great so far.
Old Aug 18, 2011 | 11:33 AM
hessdawg's Avatar
thanks for the tip
since i angled the injectors the bottom of the o-ring sits right up against the manifold.
i will br running a megasquirt to control fuel and timing
Old Aug 18, 2011 | 12:11 PM
car guy
Originally Posted by hessdawg
thanks for the tip
Sweet....please continue to share the progress.
Old Aug 18, 2011 | 12:32 PM
507OLDS's Avatar
Do you have a picture of the runner showing the injector installed?
Old Aug 18, 2011 | 12:35 PM
Land Yacht Captain
Are you building the megasquirt controller yourself? What version are you running?
Old Aug 21, 2011 | 09:10 PM
hessdawg's Avatar
shoot i thought i took a pic but i guess i didnt
Old Aug 23, 2011 | 09:30 AM
hessdawg's Avatar
havent bought the ms yet
I really want to build a ms3x but we will see if the funds permit
Old Aug 23, 2011 | 09:52 AM
Interesting!!! Waiting to see how it turns out!
Old Aug 23, 2011 | 09:55 AM
Land Yacht Captain
Having installed a few of these over the years may I recommend having someone do the tuning for you. It is a real PITA and it doesn't take much in the wrong direction to damage the engine.
Old Aug 23, 2011 | 08:41 PM
hessdawg's Avatar
got the valve covers on
got fuel rail mounted
got injectors wired and pcv run
Old Aug 23, 2011 | 08:45 PM
hessdawg's Avatar
I hear you. I just converted my 92 zx7r ninja to efi, and i would have paid money to to have a tech line to call. lol
i wish there was a local tuner that was familiar with ms
Old Aug 23, 2011 | 09:21 PM
ah64pilot's Avatar
That is BA! Is the EFI a fuel mileage thing or a power thing or both? It seems like a lot of work but it is definitely going to be one-off! Looks really good! I love the valve covers, wish I could spend the money on some like that...chrome will do for now.
Old Aug 24, 2011 | 09:34 AM
hessdawg's Avatar
i got the valve covers off ebay a few years ago then some guy was building them for $197. they fit pretty good too
Old Aug 24, 2011 | 10:07 AM
Land Yacht Captain
Very nice. Where did you get the throttle body? That thing is going to look beautiful!!! Shame to start it up and get it dirty!!!
Old Aug 24, 2011 | 10:11 AM
hessdawg's Avatar
the TB is an MSD they stopped building them a while back
i think i got this one on ebay got $250
Old Sep 9, 2011 | 06:59 PM
Vega's Avatar
Wow, i may be a little slow on the draw here but thats some amazing work you've done
Ive seen a few EFI Olds 350s running around but its pretty rare to see a 455 with it, its something ive been wanting to do with my rebuild. Ive always wondered how good i could get mileage while still pulling monster big block torque xD ive heard of people on here pulling 15mpg in the city on built 455s, thats getting dangerously close to my 3rd gen camaro's dinky smogged TBI 305 0_0 hell id do that swap any day haha
Old Sep 10, 2011 | 05:14 AM
cutlassefi's Avatar
This is me
http://www.youtube.com/watch?v=RnSi6FgMXjE
Let me know if I can help. But I have to say I'm not a real MS fan.
Old Sep 21, 2011 | 06:17 PM
hessdawg's Avatar
This is me
hey mark
i would love to do an accell kit but i just dont have the $2000-$3000
the only way i could do it is if they sponsored my car
but i don't know if they do that
Old Sep 22, 2011 | 04:43 AM
cutlassefi's Avatar
Based on the fact that you pretty much have everything else all the elctronics are $1850.00 with a wideband. That's ECM with a base tune, harness, and the wideband as mentioned. Imo head and shoulders above the MS.
Old Jan 3, 2012 | 08:28 PM
bmw2002e3's Avatar
EFI Geek
Great build
thanks for the tip
Hessdawg, What a NICE Build. I run Megasquirt on my 76 BMW and I'll be going full sequential spark and fuel with it. I also have a 62 Olds 88 with a 394.
Couple of questions, what did you do for spark control on this engine?
I'm new to olds, so trying to figure out my options for crank pulley/pickup arrangements. I probably will end up having to have something made up.
how did you manage fuel? In my BMW I was able to use a high pressure in-tank pump that fit from another model, so it was easy..
Cheers!
Old Jan 4, 2012 | 12:26 AM
hessdawg's Avatar
Cheers!
hey thanks
i am running an ms2 right now and an edis8 for the ignition as you can see in this pic lin the lower right by the crank pulley i have a 6.75 inch 36-1 wheel and a ford crank sensor
heres a closer shot
you can see in this picture the cop set up
and this is what my edis wiring looks like so far
i also converted the distributor over to a cam sensor so in the future i can run full sequential. but i do have i question for you on the cam sensor? should the single tooth be pointed at the pickup with the engine at tdc 1???
Old Jan 4, 2012 | 05:24 AM
cutlassefi's Avatar
That depends, he much injector timing adjustment is available on the MS?
Old Jan 4, 2012 | 10:07 AM
bmw2002e3's Avatar
EFI Geek
Wow! You basically just answered my question and that's what I plan on doing for ol beulah. (62 dynamic 88).
Yep, on my BMW the sensor is triggered at TDC 1. I drilled the upper timing chain cover and stuck a sensor in there. you want to be sure there isn't much room for play and those bosch distributors and the gear arrangement bmw uses on those cars flops around a bit. Your setup looks sound though.
Thanks for the info, and the wiring. That'll get me on my way to figuring out my install.
Old Jan 4, 2012 | 04:13 PM
cutlassefi's Avatar
Yep, on my BMW the sensor is triggered at TDC 1. I drilled the upper timing chain cover and stuck a sensor in there. you want to be sure there isn't much room for play and those bosch distributors and the gear arrangement bmw uses on those cars flops around a bit. Your setup looks sound though. If you're talking about the sensor for injector timing that won't make a bit of difference.
Old Jan 4, 2012 | 08:47 PM
  #31
hessdawg's Avatar
Yeah I'm not 100% sure the edis will work the way it's wired but fingers are crossed. The motor is back out on a stand and the old Holley 4d is back on to breaking the new motor. Cause it was pre programmed before the motor was rebuilt
Hoping to start it next week
I'll try and post a video
Old Jan 4, 2012 | 09:14 PM
  #32
bmw2002e3's Avatar
EFI Geek
I'm not trying to be contrary, but I am curious, in what ways?
Obviously a pre-built unit is easier, but i'm thinking feature set.
Also regarding your comment to cam tdc timing signal. I thought those had to be pretty static, when I designed mine, I followed what I saw on other newer cars, usually something coming off the cam, and non-adustable. Flutter from a distributor gear won't be an issue? That's good to know, as I know some people in the BMW crowd find it easier.
Cheers!
Old Jan 4, 2012 | 09:15 PM
  #33
bmw2002e3's Avatar
EFI Geek
Good deal. What coils are you using?
Old Jan 4, 2012 | 10:14 PM
  #34
hessdawg's Avatar
Coils are from a 6 cyl lincoln ls also the jag xkr not designed for edis but they are 12v
Old Jan 5, 2012 | 04:50 AM
  #35
cutlassefi's Avatar
Cheers!
Download the software of each and compare. If you're only going to run in a straightline then the MS is fine. If you want the best driving vehicle you can get in this price range then the Accel is far and away better. Why? Simple, because for one it has twice the transient fueling tables the MS does. There are other things that set it apart as well.
You normally change injector timing in 30 degree intervals, so a sensor that varies a few degrees here and there isn't critical like it is for ignition.
Hope this helps.
Old Jan 5, 2012 | 08:18 AM
  #36
bmw2002e3's Avatar
EFI Geek
Hope this helps.
I'll download the software and take a look. And thanks for the explanation, that helps quite a bit.
Old Jan 7, 2012 | 11:36 AM
  #37
hessdawg's Avatar
Hey BMW
I might have to Skype you when I get this thing wired for ms.
It's always better to have somebody that has a little more experience than I do
Old Jan 7, 2012 | 03:57 PM
  #38
bmw2002e3's Avatar
EFI Geek
Hey BMW
Sure thing!
Old Feb 13, 2012 | 12:17 AM
  #39
hessdawg's Avatar
ok working on the edis
will olds 455 start with 8-10 degrees btdc??
Old Feb 13, 2012 | 05:10 AM
  #40
cutlassefi's Avatar
Yeh why not?
