What compression ration is my pistons?
Old Aug 14, 2012 | 08:09 AM
matchek's Avatar
The engine code off of the oil filler is worn. I have a big "C" near the #1 cylinder though. Is that the "UC" engine code where I can look up in Chiltons. That is what I believed to be true, just want to be sure. In Chilton, for 1968 "UC" it is 9.0 to 1.
Old Aug 14, 2012 | 11:10 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
If it's a 2barrel, the pistons are most likely 30cc dish which ends up around 9:1 compression.
If your heads are removed The C code by your number 1 cylinder is the bore code. If the cylinder heads are still on, you most likely have small valved C type heads.
67Rocket
Aug 15, 2015 08:35 PM
Jaybird
Apr 8, 2012 11:15 PM
greenslade
Mar 29, 2011 03:56 PM
shaks 442 clone
Drivetrain/Differentials
Sep 4, 2007 08:30 AM
