Water pump and pulleys
Old Jun 2, 2014 | 07:56 PM
Shradezz70S's Avatar
I am looking for a good aluminum water pump and pulley set up for my 1970 455 Cutlass S. The car will have A/C looking for some info from anyone that has done this.
Thanks,
Mark
Old Jun 3, 2014 | 05:42 PM
The aluminum pumps I have seen (FlowKooler) are made for the later '71 and up engines with the smaller inlet on the pump ('68-'70=2" water pump inlet and 1.75" radiator outlet; '71-up=1.75" water pump inlet and 1.5" radiator outlet). I guess you could swap out your radiator, or just have a shop swap the outlet hose fitting for a 1.5" one and then change your lower hose to a '71-'72 version.
I have no idea about aluminum pulleys.
Old Jun 8, 2014 | 06:42 AM
Thanks for the info. I will be picking up a new aluminum radiator so I will get one that works for the pump.
Dave Siltman
Jul 24, 2014 02:55 AM
bronze66f85
Oct 22, 2013 08:27 PM
68 D88
Mar 23, 2013 06:24 AM
jdana24
Nov 29, 2012 10:26 AM
silverriff
Jun 9, 2008 02:43 PM
