water pump 66 toro
water pump 66 toro
Can you help please ??
The flange (that the pulley attaches to on the water pump shaft ) I presume that to get this off just use a puller ? Itried this and it hasn`t budged ,yet .OR is my assumption that it is just a force fit incorrect ??
thanks
mike
thanks
mike
I'm not sure the flange is integral to the shaft (at least not on some versions) but replacement pumps are under USD $30. I'm not sure how hard it is to get one where you are, however.
TX JOE,
as there is absolutely no movement in the shaft and it turns smoothly I think I may assume it is ok at this juncture.Will send to the states for another if need be --you guessed it ,not much around here in way of parts.
I am like a kid --gotta pull things apart
cheers
mike
cheers
mike
Nor Cal Andy
March 29th, 2012 07:27 PM
