water pump 455
Old Jul 4, 2023 | 08:47 PM
75royal88's Avatar
water pump 455
in my experience water pumps fail a bit and leak out of weep hole and progressively the bearing gets worse.
my wife was driving and said there was a big puddle of coolant beneath car. the water pump spins and doesnt make noise , looks like theres supposd to be some sort of cap right behind the pulley on the pump; its not there. when engine runs theres no pressure on the top hose going back to radiator. i have changed tstat and refilled the block there but it still doesnt seem to be applying pressure to top hose. any ideas?
Old Jul 5, 2023 | 06:27 AM
sysmg's Avatar
Do you see any wet spots on the engine? How much coolant?
Old Jul 5, 2023 | 08:05 AM
Oldsguy's Avatar
Past Administrator
A picture of your pump and the "cap" you are referring to might help. The only thing I can think of is the water bypass from the tstat housing to the pump. There should be a short hose from one to the other. If this isn't what you are talking about, please specify. As to why there is no pressure on the return hose, it may be that when you replaced the thermostat you put it in backwards, or it is faulty, or the engine didn't warm up enough. Just some guesses on that.
Old Jul 16, 2023 | 08:17 PM
75royal88's Avatar
replacing the thermostat did the trick ,so odd.
therobski
Sep 21, 2023 12:45 PM
70GT
Jul 14, 2023 02:48 PM
Walterdurbin
Tech Editor's Desk
May 12, 2016 03:32 PM
ejhoggard
May 15, 2012 06:03 PM
1973oldsomega
Mar 23, 2009 08:31 AM
