Water Pump for 455?
Old Feb 29, 2016 | 09:58 PM
AK71CutlassS's Avatar
Water Pump for 455?
Looking for suggestions on a water pump for my 455 build. Currently have a 1971 Cutlass S with a 350 non AC. I beleive its a 5.09 length pump. Thanks in advance
Old Feb 29, 2016 | 11:21 PM
svnt442's Avatar
Get a new replacement pump for your 350 if you plan on using the pulleys and accessories from it.
Old Feb 29, 2016 | 11:24 PM
what is the best pump for a non AC 350 I can get that is 5.09
Old Feb 29, 2016 | 11:35 PM
svnt442's Avatar
I don't know that there really is a better choice.
Old Feb 29, 2016 | 11:39 PM
No different brands. Aftermarket?
Old Mar 1, 2016 | 03:36 AM
RocketDevo's Avatar
The factory water pumps get the job done. If you keep it stock the non AC water pump casting number is 408328 for 1971-72. It is the same part number for 350 and 455.
Old Mar 1, 2016 | 05:10 AM
70cutty's Avatar
Beer Connoisseur
I have milodon aluminum water pump on mine.
Old Mar 1, 2016 | 06:29 AM
svnt442's Avatar
All of the aftermarket aluminum pumps I found were listed as 6" length pumps.
Old Mar 2, 2016 | 01:17 AM
Yeah me as well. If I could find a aftermarket pump 5.09 length I'd get it. Not finding one anywhere
Old Mar 2, 2016 | 09:13 AM
Chesrown 67 OAI's Avatar
GMB aluminum pump is what i use -- 5" shaft height. Available at advance auto for a lot less than summitt. GMB part number 130-1260AL.
Heres one for cheap:
http://www.partsgeek.com/wxs77f8-old...ile+Water+Pump
Old Mar 2, 2016 | 09:22 AM
And another link --
http://autoplicity.com/3732598-gmb-n...rCEaAucQ8P8HAQ
Old Mar 2, 2016 | 09:40 AM
Well -- i guess youre on your own -- here is a chart that lists all 3 different lengths being a use on 1971 350 engines. Actually i have not been able to fine the exact shaft length for the 130-1260 today - so you need to verify it is the one that will match your pulleys.
i actually i am using a pulley set off a 73 350 on this pump on my 400 in a 67.
http://www.oldsmobility.com/oldsmo/v....php?f=6&t=391
Old Mar 2, 2016 | 09:49 AM
I just found where the GMB 130-1260AL pump has hub height of 5.95" so it wont work on your motor if you need the 5.09 one -- unless you get a set of pulleys that match it?
Old May 20, 2024 | 05:20 AM
Shredder's Avatar
Old May 20, 2024 | 08:57 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
I'm using flowkooler 1776 it's for a 350 bracket with no ac
Old May 20, 2024 | 08:53 PM
This thread is from 2016.
Nor Cal Andy
Mar 29, 2012 07:27 PM
oldsonharmont
Jun 22, 2010 09:41 AM
AZ442
Nov 26, 2009 07:18 AM
72Ctlss
Jun 23, 2009 03:12 PM
greener_dude
Feb 18, 2007 08:14 PM
