Water neck repair
Old May 1, 2022 | 07:14 AM
MO Olds 2022's Avatar
Water neck repair
The down tube in this water neck was rusted but I managed to remove it. I've read on this site that the aftermarkets are poor quality or don't line up correctly so am hoping to keep it. But open to suggestions.
Has anyone tried to do a similar repair to install a new pipe and can share tips?
Original 455 water neck outlet
Old May 1, 2022 | 07:23 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
well a new one wont break the bank, cast is what 45 bucks and alum 28.
https://www.supercarsunlimited.com/T...ings-i160.aspx
Old May 1, 2022 | 09:29 AM
69HO43's Avatar
Not mine, but here's an NOS GM, p/n 12302551. 26.95 plus applicable tax. Free ship. Doesn't get any better than this.
12302551 Engine Coolant Thermostat Housing OEM NOS GM Part Free Shipping | eBay
Old May 1, 2022 | 10:09 AM
PatL's Avatar
there are two versions out there that I know of. I bought that GM #12302551 from Year One years ago and it was slightly offset as the OP said and it did not fit my 71 350. Ended up tracking down GM #409037 on Ebay, which is a perfect fit and called out in the parts manual. The 12302551 was used on Cadillacs, etc.
Old May 1, 2022 | 05:53 PM
69HO43's Avatar
It was likely used on Cadillacs that were equipped with Oldsmobile engines. 12302551 is the supersession part number for Oldsmobile. Whether it fits exactly the same or not, that's another issue. But that's the part number to replace 409037. You don't want to use it, fine by me.
Old May 1, 2022 | 06:29 PM
66SportCoupe's Avatar
Buy a new one.
Old May 7, 2022 | 02:33 PM
Thanks for the replies. Buying new is easier probably precovid or when you could walk into a store and purchase.
After some research, wanted to share what I did. I took a 1/2" NPT tap and ran in through the bottom. Took a Dorman 56360 heater fitting ( 3/4 In. Hose X 1/2 In. Npt X 1-3/4 In. Long Nipple) and threaded it in with pipe sealant making sure it's only on the threads. Fits perfectly but will need to use a Gates 20333 coolant hose like on early cutlasses, etc.
Hope this helps someone in the future.
Old May 7, 2022 | 11:51 PM
cfair's Avatar
Somewhere along the line I read that Olds changed the early rubber “J” hose to later design with the “J” bend made in steel because the “J” hoses had a higher failure frequency.
The later part was a simple straight hose from the “J” bend to the water pump.
So, by making the “J” curve in metal they arrived at a more durable design with fewer in service failures.
I suspect the later design works better. But I’ve never had a failure in my early, rubber. “J” hoses.
If you’re going aftermarket, go for a straight hose. If going for originality with mid-60’s, a factory a “J” hose is your friend.
Cheers
Chris
Burd
Dec 18, 2021 07:09 PM
Hairy Olds
Dec 17, 2021 06:05 PM
solly
Care and Appearance
Jul 3, 2020 04:59 PM
rustyroger
Tech Editor's Desk
Oct 10, 2013 06:49 PM
1973olds98
Body work
Jul 3, 2010 07:42 PM
