Watch out for thrust bearing clearnce.
Old Apr 4, 2017 | 10:03 AM
74sprint's Avatar
Exclamation Watch out for thrust bearing clearnce.
Has anyone else notice that on 98 & 88 455's from 68 to 72 sometimes have cast iron pulleys ? We have noticed that almost everyone of these engines have damaged/worn out thrust bearing surfaces where metal has transferred from the crank to the thrust bearing and along with embedded hard carbon have worn out the crank? You grab the front of the crank or use a tire iron and there is like 0.125" play or even more on the crank. So watch out for engines with the cast iron pulley's, they are heavy and slam the crank against the thrust bearing a lot harder than the pressed steel ones.
Ray
Old Sep 1, 2020 | 03:24 PM
chasman414's Avatar
Thanks Ray, but I'm running an aluminum reduction pulley set, and an ATI Harmonic balancer. I have run this engine for almost 14 years without this kind of damage. I've also had the same TH400 trans all those years and the same Cone converter!! But I'm happy to get any replies because one of them could hit on my problem.
Charlie
Old Sep 1, 2020 | 04:20 PM
cutlassefi's Avatar
The material has nothing to do with it. It’s either a balance problem or there is something “pulling” the crank against the thrust. It doesn’t just happen by itself.
olds70supreme
Sep 3, 2018 04:53 PM
1971 442 convert
Jun 13, 2015 02:37 PM
boese1978
Feb 14, 2014 10:58 AM
walkerse
Oct 26, 2013 12:40 PM
RAMBOW
Mar 9, 2011 04:55 PM
