W30 Intake
Old Sep 23, 2010 | 07:37 PM
2oldsguy's Avatar
W30 Intake
I have 70 442 with a W30 intake and F heads.
I believe I have a vacuum leak on the intake that I cannot detect from the top.
The ignition has been checked with an osciloscope, compression is great, and tried two carbs.
I have a LM2 A/F set up on the car and it is running lean at idle.
Has anyone had any issues with the W30 intake? Cracks, warping or sealing issues with the tin gaskets?
Thanks,
Joe
Old Sep 23, 2010 | 08:50 PM
stevengerard's Avatar
I have an intake leak now with the tin gasket, from the research I have done on this site come winter I will take it off and use a good standard gasket I got the MR Gasket ultra seal III and then use a sealant on the front and back ends.... I am sure someone with more details and real engine building experience will chime in.
Old Sep 24, 2010 | 07:29 AM
Well, the factory used the metal gasket on the W-30 cars with no problems. And yes, it is possible for the aluminum intakes to develop cracks, but it's just as possible that this is just a gasket leak. I would suggest having a machine shop dye penetrant inspect the manifold once it's off.
70-442-W30
Sep 2, 2024 11:47 PM
Nickyloves442s
Oct 24, 2012 04:55 PM
Vader
Apr 18, 2012 05:41 AM
svnt442
Jul 17, 2011 04:43 PM
mdk442
Dec 3, 2006 06:01 PM
