valvetrain clattering
Old Mar 30, 2007 | 03:25 AM
davy5's Avatar
I bought a secondhand 455 '70 engine with bad crankshaft. After replacing bearings and crankshaft build this engine in my TransAm '79. At about 1500/1700 rpm valvetrain starts clattering. I replaced valvesprings but problem remains. Does anyone have suggetions? Dots on camshaft and crankshaft I placed in line.
Old Mar 30, 2007 | 05:00 AM
Oldsguy's Avatar
Past Administrator
Provide some more info. Did you rebuild the engine completely or just the bottom end? If you replaced the cam and valve train did you pre lube the cam and the lifter surfaces? Stock rocker arms? etc.....
Old Mar 30, 2007 | 06:34 AM
Deltarocket's Avatar
If you're using adjustable rockers, how did you adjust them ?
If not, did you measure the preload on the lifters before tightening down ?
What's your oil pressure ?
Old Mar 30, 2007 | 09:53 AM
Oldsmaniac's Avatar
Heavy pre-ignition or spark knock can sound like valve clattering....actually valves dont clatter....lifters and rockers can tap. Run premium fuel and make sure timing is not advanced too far.
Old Mar 30, 2007 | 04:37 PM
davy5's Avatar
I only replaced the bearings and crankshaft. I do not have any information about what the previous owner has done with this engine. It has stock rocker arms. I did not measure the preload of the lifters. Oil pressure is OK. Ignition time was set whit little advance. If run idle engine sounds fantastic and smooth but as said before with 1500 rpm a real naisty metallic clattering occurs in the valvetrain area. Is it possible that the dots on cam and crank do not must be exactly in line? I read this in the technical bulletin on this site.
Or is this a problem with the lifters?
Old Mar 31, 2007 | 05:59 PM
I would go back and reset the rockers. This time check the preload. The preload should be around 40 thousands.
Old Apr 2, 2007 | 05:35 AM
Oldsguy's Avatar
Past Administrator
If the alignment of the camshaft was advanced by say, 4* then you might get pre-ignition but backing off on the timing would probably correct that at the expense of low engine speed performance. What I mean is, it might be a way to verify what you suspect about the timng chain but not a permanent fix. If after checking pre-load and you still have that problem you could loosen the distributor a little, hold it in place and have a partner start and bring the engine speed up for you, when it begins to clatter you could then back off the timing a little and see if that corrects it. If it does that might be an indication that the initial camshaft angle is set at the advanced point. It might be worth a try anyway.
Old Apr 2, 2007 | 03:57 PM
Being that the stock rocker configuration has no adjustment, if a smaller than stock base circle camshaft was used, and the aluminum bridges were not shimmed properly, this would be one of the possibilities. This is what I'm referring to.
Old Apr 5, 2007 | 03:20 AM
88 coupe's Avatar
Junior Member
Hi all,
Deltarocket: If a smaller than stock base circle camshaft was used, lash would be increased on all valves, and the sound would be present at idle. His "clattering" appears at 1500 RPM. If the problem was in the valve train, shims under the trunnions would only make it worse. Lifter preload only needs to be less than zero, and can exceed your .04" by as much as the plunger can travel.
davy5: Did you check all clearances on the crank/bearings? Did you inspect the rest of the engine while you had it apart? Did you tighten the TC bolts when you put the engine back in? Why did you replace the valve springs?
Does the noise appear only under load, or also in neutral? Cold or at normal operating temp?
To check valve lash:
Remove both valve covers.
Start the engine and let it idle.
Place a finger on the #1 intake rocker, where it meets the push rod, and put a small amount of pressure there.
If it is loose you will feel the slack.
Repeat on all rockers.
Norm
Old Apr 5, 2007 | 07:50 AM
88 Coupe, I meant to put the +/- on the shims. Bottom line, if a camshaft was used, that has a different base circle than what came with car. The stock push rods will no longer work.
Above the 1500 rpms, the lifters would be pumped up with more oil, making the sound less obvious. The fix would be to get the proper lenght push rod, or to go with adjustable rockers.
Old Apr 5, 2007 | 05:21 PM
88 coupe's Avatar
Junior Member
Originally Posted by Deltarocket
I meant to put the +/- on the shims ........
There are no shims on the stock rocker assemblies, and you do not know the dimensions of the cam. Reread my previous post.
........ if a camshaft was used, that has a different base circle than what came with car. The stock push rods will no longer work ........
We do not know that he has such a cam. Problem with your theory is, as I said before, the ticking (clattering) associated with improper valve lash, would show up at idle. OP says there is no problem at idle.
........ Above the 1500 rpms, the lifters would be pumped up with more oil, making the sound less obvious .........
And the OP said, it gets louder (not quieter) at 1500 RPM
........ The fix would be to get the proper length push rod, or to go with adjustable rockers.
A fix can only work, if it addresses the actual problem. I have seen nothing, so far, that points to the cam as a problem.
Norm
Old Apr 5, 2007 | 07:26 PM
Norm
Seen ? you've seen his engine ? As for shims, they are available, they do exist, and I have used them in order to correct a similar sounding problem on a friends engine. Please keep in mind, that it's all speculation at this point, since it is rather hard to diagnose a problem over the internet. I was just giving my .2cents.
Old Apr 5, 2007 | 08:41 PM
88 coupe's Avatar
Junior Member
Originally Posted by ”Deltarocket”
Seen ? you've seen his engine ? ……..
Did I say I did?
No, I still do not see it.
…….. As for shims, they are available, they do exist ……..
Yes they are. Did I say they were not?
I said, they did not come on the stock Olds trunnions. I said it is impossible for them to do, what you said they would. I did not say they were not available.
…….. I have used them in order to correct a similar sounding problem on a friends engine ……..
Similar sounding? On a friends car? Does that mean both problems are the same, and both cures will be the same?
…….. Please keep in mind, that it's all speculation at this point ……..
It is always in my mind when I’m troubleshooting any automotive problem. Doesn't that make it rather silly to suggest that the OP buy adjustable rockers, pushrods, and/or shims?
…….. since it is rather hard to diagnose a problem over the internet ……..
It is. Because it is, there are many “experts” who immediately give the OP a list of parts to change, “because it’s how my buddy fixed a similar problem”.
It never matters, that the OP bought and installed a thousand dollars worth of parts on that list, before he discovered the culprit was a vacuum leak.
…….. I was just giving my .2 cents.
Yes, you were, along with a little misinformation.
Here is mine: I do not randomly throw parts at a problem until it repairs itself. Moreover, when someone is led in that direction, I will do my best to get him back on track. As I have, in this case.
Norm
Old Apr 5, 2007 | 09:29 PM
Sad way to exist dude.... later
Old Apr 24, 2007 | 06:23 AM
bennymac's Avatar
I have the same clatter noise and can't figure it out. It seem to get worse when the timing is advanced, but does not go away when i retard it. Davy5 did u ever get the problem resolved?
Old Apr 24, 2007 | 10:00 AM
Too much compression for the fuel you're burning.
Thufir
Brakes/Hydraulic Systems
Sep 3, 2014 06:40 AM
Hetman
Aug 24, 2012 01:19 PM
64oldsguy
Aug 7, 2011 08:40 PM
70cutty
Aug 15, 2008 09:45 PM
SPEEDROCKET
Dec 18, 2007 05:58 PM
