Vacuum with 308 cam
Vacuum with 308 cam
Has anybody measured the vacuum on a 455 with 308* cam installed? Just curious, as that's the cam the '68 H/O came with from the factory... mine won't be running for a while. The 328* cam wouldn't support power brakes, but the '68 H/O came with power brakes and the 308* cam, so it had to be somewhat better.
Thanks!
Thanks!
Thanks!
Thanks!
Thanks guys. Costpenn, appreciate your offer to measure, I'd be curious for the vacuum values at idle and also 1200 rpm.
This will eventually run at the Pure Stock drags, so I may have to run the power brakes unless they were optional on H/O (believe they were standard, but I'm out of town so I can't check documentation). The rules require 16 in-hg @ 1200 rpm (with exemptions for factory combos that can't meet that rule)... I am suspecting the 308* cam will be an exemption.
I have 3.91 gears in it, so I'm not worried about the power band aspect.
A 1200 rpm idle it should pull 16 inches. it helps if you use manifold vacume on the vacume advance .BTW I do know that I have had a camshafts with 230 @ 50 cut on a 110 lobe separation run 14 to 15 inches @ 700 out of gear.
Thanks guys. The rhoads lifters aren't legal, I've gotta run the stock cam and was curious to see if it met that rule or not... Sounds like it will be just on the edge. Dave H provided some feedback that his ram rod got exempted.
sx455raidercelticfan
November 10th, 2010 08:27 PM
