Vac line ?
Old Jun 12, 2026 | 07:28 PM
Gene kerr's Avatar
Vac line ?
1970 442 is it OK to T the pcv valve hose off the power brake vac hose or will that take away vac from the brakes
Old Jun 12, 2026 | 07:41 PM
rocketraider's Avatar
Oldsdruid
I'd have some concern about oil vapor getting into the brake booster diaphram.
What's keeping you from routing the PCV vacuum line to the front of the carb?
Old Jun 14, 2026 | 10:43 AM
While both are at manifold vacuum, I'd run separate ports the way the factory did. The PCV should go to the base of the carb. The booster can be fed from a fitting in one of the runners if there isn't a port on the back of the carb.
Feb 25, 2026 11:55 AM
ourkid2000
Brakes/Hydraulic Systems
21
Apr 21, 2025 05:30 AM
bob p
Nov 30, 2020 09:25 AM
NotDads442
Dec 20, 2018 05:13 AM
classicmuscle442
Dec 16, 2018 05:55 PM
