Unidentifiable camshaft.
Old Jan 6, 2024 | 05:02 PM
Dtransplus's Avatar
I have a rebuilt '66 E shortblock that I decided to finish building. Pulled the new camshaft out of it to find out what it is. Besides the CMC machine brand core casting between the lobe and bearing journal, there is a number stamped in the back end. 920029. I went through all the manufacturers I could find and none of them have a sku number or part number anywhere close. Even Oldsmobile factory part numbers. What the heck is this thing? Ideas? Thanks!
Old Jan 6, 2024 | 06:48 PM
70W-32's Avatar
Can you post a picture of the front, where the timing sprocket mounts
Old Jan 7, 2024 | 07:38 AM
If there aren’t enough identifying markings, make some measurements to determine what grind it is.
With the cam out, you can measure the lobe lift with a micrometer or calipers. Then with it installed and the timing chain connected, use a degree wheel to measure the intake opening and closing points.
Old Jan 9, 2024 | 05:04 AM
BillK's Avatar
Do you have a picture of the back of the cam with the number ?
Old Jan 9, 2024 | 09:26 AM
BackInTheGame's Avatar
Post #1, 4th pic.
Old Jan 11, 2024 | 04:05 AM
chadman's Avatar
The best way to find out what you have:
1) put cam back in
2) set up a degree wheel and pointer
3) measure actual .050 opening and closing events, lift, LSA etc. using a dial indicator
Kjellat
Aug 25, 2023 06:33 AM
jensenracing77
Jul 30, 2017 05:47 PM
Alg
Jan 1, 2013 05:04 PM
olds4life
Jul 15, 2009 01:21 PM
tuellbox
Dec 17, 2007 04:48 PM
