Tricks to getting oil pump pickup in?
Old Jan 16, 2013 | 04:32 PM
RAMBOW's Avatar
Ben
Feel dumb asking this... I've installed oil pump pickups before, basically a crescent wrench over the shoulder on the pickup tube and whack it in- but the one for my 455 isn't budging- and the wrench is starting to dig into the shoulder on the pipe...
I even tried sticking it in the freezer for an hour first- can't get it more than a 1/4" in
Any tips?
This is a melling standard volume pump & pickup.
thanks
Old Jan 16, 2013 | 05:13 PM
OldsMotion's Avatar
OldsMotion
There may be a burr in either the casting of the pump or on the pick up. I had the same issue on my last 403 build. I had to use a little emery paper on the pickup, and some 3 in 1 oil on the tube before I tapped it in. Then I used the wrench, just like you did to tap it in place. Come to find out, the way the pump was cast, the pickup did have a little space between the pump and the knurl on the pickup.
I'm sure you have done it a dozen or more times, but make sure the pickup is going in perfectly straight, and rotate the wrench as you tap it into place.
hope that helps a little.
John
Old Jan 16, 2013 | 05:19 PM
coppercutlass's Avatar
Chevy budget Olds powered
De burr the inlet of the pump housing with some sand paper and clean it . The sand the pipe that goes in. Then apply some grease or cam break in lube and work it in. I had this happen to me as well.
csouth
Aug 26, 2012 06:16 PM
RAMBOW
Feb 25, 2012 11:31 AM
88hurstolds
Oct 6, 2011 08:26 PM
1FSTLS1
Jan 16, 2011 02:32 PM
cts-v
May 26, 2009 06:52 PM
